new build system
Richard Tran Mills
rmills at ornl.gov
Thu Jun 14 14:36:44 CDT 2007
Folks,
I agree with Leif and Stephan that the API changes between sub-sub-versions of
PETSc can be a headache. That said, I almost always LIKE the API changes
because they usually are more intuitive, consistent, etc.
I work on a Fortran code for groundwater simulation that is built on PETSc.
To allow the code to build with some different versions of PETSc, we have
introduced some wrappers. Our source code tracks PETSc-dev, but to make it
compatible with "release" versions (the example below is for 2.3.2) we do the
following. We have an include file (included by all of our source files) that
contains
#if (PETSC_VERSION_RELEASE == 1 && PETSC_VERSION_SUBMINOR < 3)
! Name differences between petsc-dev and petsc-release.
#define SNESMonitorSet SNESSetMonitor
#define MatCreateMFFD MatCreateSNESMF
#define MatMFFDSetType MatSNESMFSetType
#define MATMFFD_WP MATSNESMF_WP
#define MatMFFDGetH MatSNESMFGetH
#define MatMFFDSetHHistory MatSNESMFSetHHistory
#define IS_COLORING_GLOBAL IS_COLORING_LOCAL
! Wrappers to handle prototype differences between petsc-dev and petsc-release.
#define VecScatterBegin VecScatterBegin_wrap
#define VecScatterEnd VecScatterEnd_wrap
#endif
And then to handle the prototype differences we have a module that looks like
module PetscRelWrappers
private
public :: VecScatterBegin_wrap, VecScatterEnd_wrap
#include "include/finclude/petsc.h"
#include "include/finclude/petscvec.h"
#include "include/finclude/petscvec.h90"
contains
subroutine VecScatterBegin_wrap(inctx,x,y,addv,mode,ierr)
implicit none
VecScatter, intent(in) :: inctx
Vec, intent(in) :: x
Vec, intent(out) :: y
InsertMode, intent(in) :: addv
ScatterMode, intent(in) :: mode
PetscErrorCode, intent(out) :: ierr
call VecScatterBegin(x,y,addv,mode,inctx,ierr)
end subroutine VecScatterBegin_wrap
subroutine VecScatterEnd_wrap(inctx,x,y,addv,mode,ierr)
implicit none
call VecScatterEnd(x,y,addv,mode,inctx,ierr)
end subroutine VecScatterEnd_wrap
#endif
end module PetscRelWrappers
This allows our code to compile fine with PETSc 2.3.2 even though internally
our code uses the 2.3.3 (petsc-dev, actually) interfaces. It would also be
easy to do the same sort of thing to allow code that uses the 2.3.2 interfaces
to compile with 2.3.3.
It might be a good idea to have some officially maintained wrappers like this
(wrapping "older" PETSc interfaces to the new ones), although that might get a
little messy (maybe more than a little).
I always insist on upgrading code to use the latest PETSc, but I know that
there are people who either don't care to do this or who simple cannot due to
circumstances beyond their control. Folks installed PETSc from a package are
probably not going to want to have to do this.
Best regards,
Richard Mills
Leif Strand wrote:
> Stephan Kramer wrote:
>> In that respect a related question: is it really necessary to have
>> incompatible changes between sub-sub-versions of PETSc? Most software
>> only makes backwards-incompatible changes when bumping their mayor
>> version number. I must say that I was not really amused when I found out
>> our software would not build with PETSc 2.3.3, because of various small
>> namechanges, such as KSPSetMonitor -> KSPMonitorSet.
> I second all of this. This is a much bigger issue than build system,
> directory layout, etc. As a library maintainer, one needs religion about
> this sort of thing. I would expect any library not to make gratuitous
> changes to the API from one update to the next, and to have a sane
> version numbering scheme.
> So the number of changes between PETSc 2.3.2 and 2.3.3 was a bit
> surprising. Given that it adds new features (Sieve), one could argue
> that it should have been called PETSc 2.4. Given the number of
> incompatibility-inducing changes (order-of-args for
> VecScatter{Begin,End}, KSPDefaultSMonitor -> KSPMonitorDefault, etc.) I
> would argue it should have been called PETSc 3.0. If you're really
> ambitious, you could implement a separate API layer, and applications
> can choose which API version they want to use (using a #define, for
> example). Otherwise, branch management is a must.
Richard Tran Mills, Ph.D.
Computational Scientist E-mail: rmills at ornl.gov
Computational Earth Sciences Group Phone: (865) 241-3198
Oak Ridge National Laboratory Fax: (865) 574-0405
