new build system
Leif Strand leif at geodynamics.org
Thu Jun 14 13:59:23 CDT 2007
Stephan Kramer wrote:
> In that respect a related question: is it really necessary to have
> incompatible changes between sub-sub-versions of PETSc? Most software
> only makes backwards-incompatible changes when bumping their mayor
> version number. I must say that I was not really amused when I found out
> our software would not build with PETSc 2.3.3, because of various small
> namechanges, such as KSPSetMonitor -> KSPMonitorSet.
I second all of this. This is a much bigger issue than build system,
directory layout, etc. As a library maintainer, one needs religion about
this sort of thing. I would expect any library not to make gratuitous
changes to the API from one update to the next, and to have a sane
version numbering scheme.
So the number of changes between PETSc 2.3.2 and 2.3.3 was a bit
surprising. Given that it adds new features (Sieve), one could argue
that it should have been called PETSc 2.4. Given the number of
incompatibility-inducing changes (order-of-args for
VecScatter{Begin,End}, KSPDefaultSMonitor -> KSPMonitorDefault, etc.) I
would argue it should have been called PETSc 3.0. If you're really
ambitious, you could implement a separate API layer, and applications
can choose which API version they want to use (using a #define, for
example). Otherwise, branch management is a must.
Regarding multiple configurations: I would try to reduce the number of
possible configurations, rather than invent an elaborate
multi-configuration install/build directory layout scheme. Ideally,
there should be only one possible configuration. Decide upon one way of
doing things.
A common mistake is to punt on every single difficult design decision by
turning it into an "option". Over time, this leads to huge "Preferences"
dialogs and configure scripts with a hundred options. This places a
burden upon the end user; they won't thank you for being offered so many
choices. Regarding PETSc, one of my pet peeves is the "--with-c-support"
option. Why not just *always* wrap everything in [extern "C"]? Not only
is the default wrong; this is a non-option. I can't think of any reason
why anyone would even want a choice. Taking a step back,
"--with-clanguage" is evil as well. At some point, you should decide
whether PETSc is C code, or C++ code.
Another common mistake is to make decisions at configure/compile-time
that could be made at runtime. I've seen people insert #ifdef X when "if
(x) {}" would have worked just as well. Regarding PETSc, applying this
principle to dependencies might be helpful. For example, pretend I want
to switch from Chaco to Parmetis or vice-versa. AFAIKT, the current
situation is that I would need two completely different
builds/configurations of PETSc. Ideally I could do it at runtime using
some sort of partitioner-plugin scheme. This might mean splintering
parts PETSc off into separate satellite packages (e.g., "the Chaco
plug-in for PETSc"). Debian/RPM packagers would thank you for it.
--Leif Strand
