changes to PETSc-dev bmake system and library locations
Barry Smith
bsmith at mcs.anl.gov
Fri Jun 8 20:02:25 CDT 2007
PETSc-dev users,
After picking Satish's brain, I have made a set of changes to
petsc-dev related to compiling and linking programs.
Goal: Support the GNU; config/configure.py; make; make install model
including all external packages PETSc builds for you. After "make install"
PETSC_ARCH should not be needed.
Constraints:
* Allow skipping the "make install" step and yet having everything
fully functional even with shared and dynamic libraries
* Allow multiple builds in the non-"make install" approach which you can
switch between by changing PETSC_ARCH
* Not require any file links
* A system that does not mix generated files and non-generated in the same
directory in $PETSC_DIR
* A system no more complicated then the previous version.
Solution:
In place, before "make install"
petsc-dev/include same as now
/bin same as now
/conf basically the same as bmake/common was
$PETSC_ARCH/include generated includes: petscconf.h petscfix.h ..
lib generated libraries
bin generated programs
conf basically the same as bmake/$PETSC_ARCH/
except not the include files
prefix/include all includes
/bin all programs, including mpiexec, mpicc if generated
/conf the stuff previous in bmake/common and bmake/$PETSC_ARCH
/lib the libraries, including from external packages
The whole trick is that in the PETSc bmake files (now conf files :-)) the $PETSC_ARCH/
disappears in the "make install" version.
I have fixed the external packages MPI.py, BlasLapack.py and Chaco.py but the others
need to be modified to stick their libraries and includes in the new correct place.
The only change you should need to your makefiles is to replace
include ${PETSC_DIR}/bmake/common/base with
include ${PETSC_DIR}/conf/base
Bug reports to petsc-maint at mcs.anl.gov questions to petsc-dev at mcs.anl.gov
Barry
