configuration crash
Fri Dec 21 11:13:00 CST 2007
framework.Framework is a
  base.Configure is a
    script.Script is a
      logger.Logger which as closeLog()
   Matt
On Dec 21, 2007 10:25 AM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> I think no, unless 'config/configure.py' is no longer the main entry
> point for launching configuration ...
> Grepping with emacs for 'closeLog' in inside 'petsc-dev/config' I get this
> cd ~/Devel/PETSc/petsc-dev/config/
> find . -type f -print0 | xargs -0 -e grep -n -e closeLog
> Binary file ./configure.pyc matches
> ./configure.py:225:    framework.closeLog()
> Binary file ./BuildSystem/logger.pyc matches
> ./BuildSystem/logger.py:136:  def closeLog(self):
> The line in configure.py seems to be causing the problem.
> On 12/21/07, Matthew Knepley <knepley at gmail.com> wrote:
> > Is it possible that you have an old BuildSystem lying around? I ran
> > this just fine two days ago.
> >   Matt
> > On Dec 21, 2007 8:58 AM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> > > I'm getting this error at the very end of running configure.py.
> > >           CONFIGURATION CRASH  (Please send configure.log to
> > > petsc-maint at mcs.anl.gov)
> > > 'Framework' object has no attribute 'closeLog'  File
> > > "/repos/hg/petsc/petsc-dev/config/configure.py", line 225, in
> > > petsc_configure
> > > Lisandro Dalcín
> > > Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> > > Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> > > Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> > > PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> > > Tel/Fax: +54-(0)342-451.1594
> > What most experimenters take for granted before they begin their
> > experiments is infinitely more interesting than any results to which
> > their experiments lead.
> > -- Norbert Wiener
> Lisandro Dalcín
-- Norbert Wiener
