configuration crash
Lisandro Dalcin
dalcinl at gmail.com
Fri Dec 21 10:25:01 CST 2007
I think no, unless 'config/configure.py' is no longer the main entry
point for launching configuration ...
Grepping with emacs for 'closeLog' in inside 'petsc-dev/config' I get this
cd ~/Devel/PETSc/petsc-dev/config/
find . -type f -print0 | xargs -0 -e grep -n -e closeLog
Binary file ./configure.pyc matches
./configure.py:225: framework.closeLog()
Binary file ./BuildSystem/logger.pyc matches
./BuildSystem/logger.py:136: def closeLog(self):
The line in configure.py seems to be causing the problem.
On 12/21/07, Matthew Knepley <knepley at gmail.com> wrote:
> Is it possible that you have an old BuildSystem lying around? I ran
> this just fine two days ago.
> Matt
> On Dec 21, 2007 8:58 AM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> > I'm getting this error at the very end of running configure.py.
> > CONFIGURATION CRASH (Please send configure.log to
> > petsc-maint at mcs.anl.gov)
> > 'Framework' object has no attribute 'closeLog' File
> > "/repos/hg/petsc/petsc-dev/config/configure.py", line 225, in
> > petsc_configure
> > Lisandro Dalcín
> > Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC)
> > Instituto de Desarrollo Tecnológico para la Industria Química (INTEC)
> > Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET)
> > PTLC - Güemes 3450, (3000) Santa Fe, Argentina
> > Tel/Fax: +54-(0)342-451.1594
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
Lisandro Dalcín
