Why the hell did 'python' move?
Farshid Mossaiby
mossaiby at yahoo.com
Tue Dec 11 02:04:32 CST 2007
Dear PETSc developers and users,
Sorry for commenting on you really great developers...
Just wanted to say that the location of tutorials and
tests is also a bit odd *for me* (anyway I am not an
expert). I expected to see a 'samples', 'tutorials' or
something like this, but found the samples at, for
example, $PETSC_DIR/src/ksp/ksp/examples/tutorials.
Just a comment, sorry if it is non-sense.
Best regards,
Farshid Mossaiby
--- Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Dec 10, 2007, at 10:31 AM, Matthew Knepley wrote:
> > I do not remember mail about this or I would have
> complained. You
> > talked
> > about moving other things.
> It was an earlier mail
> > Python code nuder the 'python' directory makes
> > perfect sense to me. How the hell would I know
> what is in 'config'.
> > Also,
> > not all of the python code is configuration code.
> If there was python code that was not
> configuration/build code then
> I apologize about messing up that code. As far as I
> could see at that
> time
> python had the config code plus some no longer used
> code for generating
> python PETSc classes. I definitely believe all the
> config code should
> be in
> the same directory with a name that indicates it is
> config. Putting
> code in a directory named after the language it is
> written in makes
> no sense to me, the directory name should indicate
> what the code/
> directory
> is FOR; so real people can get around the directory
> tree.
> Barry
> > Matt
> > On Dec 10, 2007 10:16 AM, Barry Smith
> >> I sent email about a week ago and no one
> complained.
> >> As someone downloads petsc-dev they see
> directories config and
> >> python;
> >> this make NO SENSE at all, how are they going to
> know that most of
> >> the
> >> configure
> >> stuff is in the python directory? If I did not
> know PETSc and
> >> downloaded it
> >> I would be so pissed at the utterly stupid naming
> that I would simply
> >> delete the
> >> whole package and not even consider using it.
> Directory names are not
> >> for the developer (a developer can remember
> anything so long as the
> >> work on the package long enough), directory names
> are for the causal
> >> user and it is important that they make sense.
> >> Why does your finite element stuff care where
> the configuration
> >> code is stored???? At most you should have to
> change a couple little
> >> things.
> >> Barry
> >> On Dec 10, 2007, at 10:08 AM, Matthew Knepley
> wrote:
> >>> How does 'config' make any more sense than
> 'python'. And this
> >>> break EVERYTHING I do with finite elements. This
> should have at
> >>> least been discussed on petsc-dev.
> >>> Matt
> >>> What most experimenters take for granted before
> they begin their
> >>> experiments is infinitely more interesting than
> any results to which
> >>> their experiments lead.
> >>> -- Norbert Wiener
> they begin their
> > -- Norbert Wiener
____________________________________________________________________________________
Looking for last minute shopping deals?
Find them fast with Yahoo! Search. http://tools.search.yahoo.com/newsearch/category.php?category=shopping
