PIC
Thu Dec 15 19:54:11 CST 2005
  Satish,
   Thanks, we'll have to live with this fix.
   Barry
On Thu, 15 Dec 2005, Satish Balay wrote:
> Barry,
> I'm attaching the relavent logfiles for this failure case. Looks like
> there is an exception raised for this case - so I can trap it in
> MPI.py - and error out. [other case returns a '0' - which is ok for
> PETSc sharedlibs]
> So with this change to MPI.py, configure give a nice error message:
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
> PETSc shared libraries cannot be built using MPI provided.
> Either rebuild PETSc with --with-shared=0 or rebuild MPI with shared library support
> I'll push this change.
> Satish
> On Wed, 14 Dec 2005, Barry Smith wrote:
> > >   This also succeeds, unless I misunderstand greatly the error.
> >   The libraries get built, fine. Now you generate the executable.
> > That FAILS! As I have been saying all the time! It fails NOT
> > because the library is not shared but because one cannot use
> > that library WITH shared libraries!
> >   The new test is suppose to check that it can link and generate
> > the executable, BUT not run the executable to see what message
> > you get.
> >   The new test could be called checkCanBeUsedWithSharedLibrary() and
> > it would shared almost all the code with checkShared() except actually
> > running the executable and checking the result.
> >   Is it clear now, or am I still messed up?
