PIC
    Aron Ahmadia
    aja2111 at columbia.edu
    Wed Dec 14 09:45:19 CST 2005
>   Because the "can I" is VERY erratic. I can build some shared libraries, but
> cannot build others. I do not understand the difference between these
> libraries
> at the moment, however I DO know that absence of the PIC option causes the
> error.
Matt, I've used PIC before to sidestep errors associated with linking
libraries in the wrong order in the call to the linker.  Have you ruled this
out as your problem for the non-PIC libraries?
And how the heck do you build shared libraries that aren't PIC?
~~A
