[Parvis-users] How to compile gdal in AIX
Mary Haley
haley at ucar.edu
Wed Mar 12 19:44:44 CDT 2014
Hi Chen,
Here at NCAR we no longer have access to an AIX system, so I’m unable to help there.
Did you try the GDAL email list?
The other possibility is to try the GNU compilers if you can use these instead of xlc.
If you are needing to build GDAL for ParNCL, then I should mention that this package is optional if you don’t need shapefile support.
—Mary
On Mar 12, 2014, at 8:24 AM, 陈剑桥 <xiguli520 at 163.com> wrote:
> Hi PARVIS support ,
> Did you settle the problem http://lists.mcs.anl.gov/pipermail/parvis-users/2013-August/000018.html
> I meet the same problem when I want to compile gdal-1.10.0 by using xlc & xlC in AIX.
> How to fit it ?
> best regards!
> Chen Jian-qiao
> Fuzhou Fujian China
> +86-591-87877036
> Parvis-users mailing list
> Parvis-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/parvis-users
URL: <http://lists.mcs.anl.gov/pipermail/parvis-users/attachments/20140312/bcec5ee3/attachment.html>
More information about the Parvis-users
