Good to know the scripts are working for you now.
These warnings are ok. Some of these warnings will be eliminated in the upcoming release of ParNCL that we plan to have soon (hopefully in a month or so).
Jayesh
Sent: Wednesday, December 03, 2014 11:06 PM
To: Krishna, Jayesh
Subject: Re: parncl
Hi Jayesh,
After exporting the correct NCARG_ROOT path, I am able to run the scripts.
However, getting many warnings. for example the following:
warning:SetOption() is not supported for this option (missingtofillvalue)
warning:SetOption() is not supported for this option (cachepreemption)
warning:SetOption() is not supported for this option (cachesize)
warning:SetOption() is not supported for this option (cachenelems)
(0) check_for_y_lat_coord: Warning: Data either does not contain a valid latitude coordinate array or doesn't contain one at all.
(0) A valid latitude coordinate array should have a 'units' attribute equal to one of the following values:
(0) 'degrees_north' 'degrees-north' 'degree_north' 'degrees north' 'degrees_N' 'Degrees_north' 'degree_N' 'degreeN' 'degreesN' 'deg north'
(0) check_for_lon_coord: Warning: Data either does not contain a valid longitude coordinate array or doesn't contain one at all.
(0) A valid longitude coordinate array should have a 'units' attribute equal to one of the following values:
(0) 'degrees_east' 'degrees-east' 'degree_east' 'degrees east' 'degrees_E' 'Degrees_east' 'degree_E' 'degreeE' 'degreesE' 'deg east'
Best Regards,
Bipin
----- Original Message -----
To: "Bipin Kumar" <bipink at tropmet.res.in>
Sent: Thursday, December 4, 2014 3:13:30 AM
Subject: RE: parncl
Do you still have the problem mentioned below?
(PS: I verified that lines, 3315, mentioned in the error message below does not correspond to the version of scripts distributed with parncl. This is most likely due to NCARG_ROOT pointing to another installation of NCL.)
Jayesh
Sent: Monday, December 01, 2014 10:46 AM
To: Bipin Kumar
Subject: RE: parncl
Please also make sure that the NCARG_ROOT environment variable is set correctly to the parncl install directory before running the scripts.
export NCARG_ROOT=/gpfs3/gpfs7/home/ibm/AMIT/PARNCL/PARNCL1/PARNCL
jayesh
Sent: Monday, December 01, 2014 10:37 AM
To: Bipin Kumar
Subject: RE: parncl
Which version of ParNCL are you trying out? Please make sure that depending on the version of ParNCL source built you build/use the corresponding versions of ParGAL and MOAB libraries.
ParNCL 1.0.0 requires MOAB #3da2f0b and ParGAL 1.0.0
I will try out ParNCL 1.0.0 and see if I can recreate your issue.
Jayesh
__
___________________-
fatal:syntax error: line 3315 in file $NCARG_ROOT/lib/ncarg/nclscripts/csm/gsn_code.ncl before or near windowWorkstationClass
window = create name + "_x11" windowWorkstationClass
fatal:syntax error: line 3316 in file $NCARG_ROOT/lib/ncarg/nclscripts/csm/gsn_code.ncl before or near "wkFormat
"wkFormat"
fatal:error in statement
fatal:syntax error: line 3317 in file $NCARG_ROOT/lib/ncarg/nclscripts/csm/gsn_code.ncl before or near "wkPause
"wkPause"
fatal:syntax error: line 3318 in file $NCARG_ROOT/lib/ncarg/nclscripts/csm/gsn_code.ncl before or near "wkColorMap
"wkColorMap"
fatal:syntax error: line 3319 in file $NCARG_ROOT/lib/ncarg/nclscripts/csm/gsn_code.ncl before or near "wkWidth
"wkWidth"
_______
Dr. Bipin Kumar
Scientist 'D'
HPC, IITM Pune
Dr. Homi Bhabha Road,
Pune, 411008, INDIA
Ph:+91-2025904450
