[Parvis-users] tourbles when addfile.
Jayesh Krishna
jayesh at mcs.anl.gov
Tue Apr 2 09:55:55 CDT 2013
Were you able to get the header information in the netcdf file (ncdump -h)?
(PS: You can find information on how to build ParNCL in the wiki page - http://trac.mcs.anl.gov/projects/parvis/wiki/BuildingParNCL)
Jayesh
----- Original Message -----
To: "Matrix" <sov_matrix at 126.com>
Cc: parvis-users at lists.mcs.anl.gov
Sent: Monday, April 1, 2013 9:31:22 AM
Subject: Re: [Parvis-users] tourbles when addfile.
Can you attach the header information (ncdump -h) of the file that you are trying to read in your email?
Jayesh
To: parvis-users at lists.mcs.anl.gov
Sent: Saturday, March 30, 2013 7:41:26 AM
Subject: [Parvis-users] tourbles when addfile.
Dear Professor :
Recently , we have built the ParNCL , and met with a lot of problems. Could you give me a manual about the ParNCL,please?
when we read the cam model history file with the Parncl. Some errors occurred when we use addfile( "file", "r") , as the following:
warning:Cannot change suppress close option
w arning:SetOption() is not supported for this option (missingtofillvalue)
warning:SetOption() is not supported for this option (cachepreemption)
warning:SetOption() is not supported for this option (cachesize)
warning:SetOption() is not supported for this option (cachenelems)
fatal:Unable to load file
terminate called after throwing an instance of 'pargal::pargal_except'
what(): MB_FAILURE
With the NCL , the trouble doesn't occurred . I wonder if you have met with this trouble.
We used the NCO to extract some single variables to a new file. And any single 2D or 3D variable with the variable gw can be read by ParNCL .
for example :
ncks -v T,gw TH240_CAM-th.cam2.h0.0314-04.nc temp.nc
The new file temp.nc can be read by ParNCL smoothly. And any other 1D ,2D ,3D variable can be added to the new file without troubles.
We ask for your help ,thank you.
& nbsp; Xu, Ji
& nbsp; Tsinghua University.China
Parvis-users mailing list
Parvis-users at lists.mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/parvis-users
More information about the Parvis-users
