Error building PNetCDF 1.12.2 with NVHPC 22.1 under CentOS 8
Carl Ponder
cponder at nvidia.com
Thu Jan 27 15:42:38 CST 2022
I'm getting this error:
/bin/gcc -I../../../src/utils/ncvalidator -o cdfdiff cdfdiff.c
In file included from /usr/include/stdlib.h:55,
from
/home/cponder/WRF/PGI/100.NVHPC/Linux_x86_64/21.11/compilers/include/stdlib.h:13,
from cdfdiff.c:19:
/home/cponder/WRF/PGI/100.NVHPC/Linux_x86_64/21.11/compilers/include/bits/floatn.h:60:17:
error: two or more data types in declaration specifiers
typedef float _Float32;
/home/cponder/WRF/PGI/100.NVHPC/Linux_x86_64/21.11/compilers/include/bits/floatn.h:63:18:
typedef double _Float64;
/home/cponder/WRF/PGI/100.NVHPC/Linux_x86_64/21.11/compilers/include/bits/floatn.h:74:18:
typedef double _Float32x;
/home/cponder/WRF/PGI/100.NVHPC/Linux_x86_64/21.11/compilers/include/bits/floatn.h:78:25:
typedef long double _Float64x;
make[3]: *** [Makefile:847: cdfdiff] Error 1
make[3]: Leaving directory
'/home/cponder/WRF/PGI/A.106.PNetCDF/distro/src/utils/ncmpidiff'
make[2]: *** [Makefile:545: all-recursive] Error 1
make[2]: Leaving directory
'/home/cponder/WRF/PGI/A.106.PNetCDF/distro/src/utils'
make[1]: *** [Makefile:476: all-recursive] Error 1
make[1]: Leaving directory
'/home/cponder/WRF/PGI/A.106.PNetCDF/distro/src'
make: *** [Makefile:533: all-recursive] Error 1
I believe the problem is that it's trying to use the system-default
*gcc* here
checking for mpiexec... /home/cponder/WRF/PGI/105.OpenMPI/bin/mpiexec
*checking for gcc... /bin/gcc**
**checking C compiler for serial utility programs... /bin/gcc*
which is incompatible with all the NVHPC_specific paths that I'm setting
for the overall build:
export CC=`which pgcc`
export CXX=`which pgc++`
export F77=`which pgf77`
export F90=`which pgf90`
export FC=`which pgfortran`
export MPICC=`which mpicc`
export MPICXX=`which mpicxx`
export MPIF77=`which mpif77`
export MPIF90=`which mpif90`
export CFLAGS="-fPIC -m64 -tp=px"
export CXXFLAGS="-fPIC -m64 -tp=px"
export FCFLAGS="-fPIC -m64 -tp=px"
export LDFLAGS+=" -L$PGI/cuda/lib64 -lnvidia-ml"
I'm guessing that the old compilers & old OS levels didn't enable these
types so there was no collision during the compilation.
Is there a way to override the *gcc* default for the utilities? I don't
see any such setting in the configure --help output.
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20220127/5c0ce392/attachment.html>
More information about the parallel-netcdf
