Path oddity in PNetCDF build/configure
Wei-Keng Liao
wkliao at northwestern.edu
Sun Oct 24 18:53:02 CDT 2021
I also suggest to remove "--enable-large-single-req".
As far as I know none of existing MPI-IO implementation
supports reading or writing > 2GB data elements in a single call.
This option is to disable an internal checking in PnetCDF
for any single request size > 2GB and let the underneath MPI-IO
to check this condition.
Wei-keng
On Oct 24, 2021, at 6:35 PM, Carl Ponder <cponder at nvidia.com<mailto:cponder at nvidia.com>> wrote:
Ok -- yes -- I got a clean build by removing the --with-mpi flag.
What about this --enable-large-single-req flag, though?
Does it require that I build OpenMPI specially, or use a specific kind of switch or FileSystem?
I only use 64-but systems these days...
Carl
Subject: Re: Path oddity in PNetCDF build/configure
Date: Sun, 24 Oct 2021 21:27:44 +0000
From: Wei-Keng Liao <wkliao at northwestern.edu><mailto:wkliao at northwestern.edu>
To: Carl Ponder <cponder at nvidia.com><mailto:cponder at nvidia.com>
CC: Bruno Pagani <bruno.pagani at astrophysics.eu><mailto:bruno.pagani at astrophysics.eu>, parallel-netcdf at lists.mcs.anl.gov<mailto:parallel-netcdf at lists.mcs.anl.gov> <parallel-netcdf at lists.mcs.anl.gov><mailto:parallel-netcdf at lists.mcs.anl.gov>
External email: Use caution opening links or attachments
I checked the configure command line used.
While debugging this issue, I suggest you to remove
"--with-mpi --enable-large-single-req" from the configure command.
Option --with-mpi was designed to let users to provide the
path of MPI installation, e.g. --with-mpi=/usr/local
Use option --enable-large-single-req is when the underlying
MPI-IO supports reading and writing more than 2GiB in a
single call (i.e. MPI_File_read and MPI_File_write call.)
Wei-keng
On Oct 24, 2021, at 4:07 PM, Carl Ponder <cponder at nvidia.com<mailto:cponder at nvidia.com>> wrote:
I attached the config.log here, but it doesn't show the steps used in the mpiccchecking:
configure:4284: result: /usr/bin/sed -i''
configure:4682: checking mpicc under yes
configure:4689: result: no
configure:4772: error:
Specified MPI C compiler "mpicc" cannot be found under yes
PnetCDF requires a working MPI C compiler. Please specify the location
of an MPI C compiler, either in the MPICC environment variable
(not CC variable) or through --with-mpi configure flag. Abort.
The command-line I used was
./configure --prefix=/usr/local --enable-shared --with-mpi --enable-large-single-req
Date: Sun, 24 Oct 2021 19:22:06 +0000
Please let me know the configure command used.
Wei-keng
Date: Sun, 24 Oct 2021 17:06:01 +0000
CC: parallel-netcdf at lists.mcs.anl.gov<mailto:parallel-netcdf at lists.mcs.anl.gov> <parallel-netcdf at lists.mcs.anl.gov><mailto:parallel-netcdf at lists.mcs.anl.gov>
Hi, Carl
Please send me the file config.log.
Wei-keng
On Oct 24, 2021, at 1:29 PM, Carl Ponder <cponder at nvidia.com<mailto:cponder at nvidia.com>> wrote:
This is in a Dockerfile rather than my usual bash scripting.
Here's the PATH being printed during the build
Step 95/156 : RUN echo ${PATH}
---> Running in 8586a4aef68a
/usr/local/nvidia/bin:/usr/local/cuda/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/bin:/usr/local/cuda/bin:/usr/local/pgi/Linux_x86_64/21.9/compilers/bin
And the mpicc location tests correctly:
Step 95/155 : RUN which mpicc
---> Running in e2161d554278
/usr/local/bin/mpicc
Date: Sun, 24 Oct 2021 16:32:42 +0400
From: Bruno Pagani <bruno.pagani at astrophysics.eu><mailto:bruno.pagani at astrophysics.eu>
To: Carl Ponder <cponder at nvidia.com><mailto:cponder at nvidia.com>, Wei-keng Liao <wkliao at eecs.northwestern.edu><mailto:wkliao at eecs.northwestern.edu>
How do you set PATH? Did you quote it? Seems somehow your path end up being yes, likely due to expansion of its previous value.
Le 24 octobre 2021 16:30:03 GMT+04:00, Carl Ponder <cponder at nvidia.com><mailto:cponder at nvidia.com> a écrit :
When I build PNetCDF with MPICC=mpicc and mpicc on my $PATH, I see this during the configure phase:
ENV PATH=${PATH}:/usr/local/bin
ENV MPICC mpicc
checking for sed handling option -i ... /usr/bin/sed -i''
checking mpicc under yes... no
configure: error:
I can work around it by making the path absolute
ENV MPICC /usr/local/bin/mpicc
checking whether /usr/local/bin/mpicc exists and is executable... yes
But, based on the first message, I'm thinking there's an incorrect path-search during the configure phase.
This is with PNetCDF 1.12.2.
<config.log>
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20211024/1bf78d93/attachment-0001.html>
More information about the parallel-netcdf
