Path oddity in PNetCDF build/configure
    Carl Ponder
    cponder at nvidia.com
    Sun Oct 24 16:07:33 CDT 2021
I attached the config.log here, but it doesn't show the steps used in
the mpicc checking:
    configure:4284: result: /usr/bin/sed -i''
    *configure:4682: checking mpicc under yes*
    configure:4689: result: no
    configure:4772: error:
          Specified MPI C compiler "mpicc" cannot be found under yes
          PnetCDF requires a working MPI C compiler. Please specify the
    location
          of an MPI C compiler, either in the MPICC environment variable
          (not CC variable) or through --with-mpi configure flag. Abort.
The command-line I used was
    ./configure --prefix=/usr/local --enable-shared --with-mpi
    --enable-large-single-req
Subject: 	Re: Path oddity in PNetCDF build/configure
Date: 	Sun, 24 Oct 2021 19:22:06 +0000
To: 	Carl Ponder <cponder at nvidia.com>
CC: 	Bruno Pagani <bruno.pagani at astrophysics.eu>,
parallel-netcdf at lists.mcs.anl.gov <parallel-netcdf at lists.mcs.anl.gov>
*External email: Use caution opening links or attachments*
Please let me know the configure command used.
Wei-keng
Date: 	Sun, 24 Oct 2021 17:06:01 +0000
CC: 	parallel-netcdf at lists.mcs.anl.gov <parallel-netcdf at lists.mcs.anl.gov>
Hi, Carl
Please send me the file config.log.
Wei-keng
> On Oct 24, 2021, at 1:29 PM, Carl Ponder <cponder at nvidia.com
> <mailto:cponder at nvidia.com>> wrote:
> This is in a Dockerfile rather than my usual bash scripting.
> Here's the PATH being printed during the build
>     Step 95/156 : RUN echo ${PATH}
>      ---> Running in 8586a4aef68a
>     /usr/local/nvidia/bin:/usr/local/cuda/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/bin:/usr/local/cuda/bin:/usr/local/pgi/Linux_x86_64/21.9/compilers/bin
> And the mpicc location tests correctly:
>     Step 95/155 : RUN which mpicc
>      ---> Running in e2161d554278
>     */usr/local/bin/mpicc*
> Date: 	Sun, 24 Oct 2021 16:32:42 +0400
> From: 	Bruno Pagani <bruno.pagani at astrophysics.eu>
> To: 	Carl Ponder <cponder at nvidia.com>, Wei-keng Liao
> <wkliao at eecs.northwestern.edu>
> How do you set PATH? Did you quote it? Seems somehow your path end up
> being yes, likely due to expansion of its previous value.
> Le 24 octobre 2021 16:30:03 GMT+04:00, Carl Ponder
> <cponder at nvidia.com> a écrit :
>     When I build PNetCDF with MPICC=mpicc and mpicc on my$PATH, I see
>     this during the configure phase:
>         ENV PATH=${PATH}:/usr/local/bin
>         ENV MPICC mpicc
>         checking for sed handling option -i ... /usr/bin/sed -i''
>         *checking mpicc under yes... no*
>         configure: error:
>         the location
>         variable
>         Abort.
>     I can work around it by making the path absolute
>         ENV MPICC /usr/local/bin/mpicc
>         *checking whether /usr/local/bin/mpicc exists and is
>         executable... yes*
>     But, based on the first message, I'm thinking there's an incorrect
>     path-search during the configure phase.
>     This is with PNetCDF 1.12.2.
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20211024/ab0c242d/attachment-0001.html>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20211024/ab0c242d/attachment-0001.bin>
More information about the parallel-netcdf
