[External] Re: nf90mpi_get_var_all error code
Kihang Youn
kyoun at lenovo.com
Tue Mar 23 04:18:48 CDT 2021
Hi Wei-keng,
<https://www.unidata.ucar.edu/software/netcdf/docs/nc-error-codes.html>
Thank you for answer and telling me how to print the error.
Pnetcdf are also using the same error system as netcdf.
Please let me share the information below for reference.
Here is the header of my netcdf file:
netcdf clim_aerosol_BC {
dimensions:
month = 12;
nlev = 16;
ncol = 3110402;
variables:
float BC(month, nlev, ncol);
double pressure(nlev);
Trying to read the second pressure variable,
I confirmed that it goes into nf90mpi_get_var_all(0, 2, VAR, 1, 16).
I thought it was a problem because VAR is a real4 variable, so I changed the pressure of the netcdf file from double to float, but it is the same.
I am now in doubt whether there was a problem with the library installation process.
Any idea what's wrong?
Best Regards,
Kihang
Kihang Youn(윤기항) - Application Analyst | Lenovo DCG Professional Services
Mobile: +82-10-9374-9396
E-mail: kyoun at lenovo.com
Sent: Tuesday, March 23, 2021 17:45
To: Kihang Youn <kyoun at lenovo.com>
Cc: parallel-netcdf at lists.mcs.anl.gov <parallel-netcdf at lists.mcs.anl.gov>
Subject: [External] Re: nf90mpi_get_var_all error code
API nf90mpi_strerror() can be used to obtain the error message, for example
err = nf90mpi_get_var_all(ncid, varid, buf, start, count)
write(6,*) "Error when calling nf90mpi_get_var_all ", trim(nf90mpi_strerror(err))
Error code -40 is constant NF90_EINVALCOORDS, which corresponds to the message below.
NetCDF: Index exceeds dimension bound
Check the argument "start" for invalid values used.
Wei-keng
On Mar 23, 2021, at 3:38 PM, Kihang Youn <kyoun at lenovo.com<mailto:kyoun at lenovo.com>> wrote:
I try to read the contents of Netcdf file with nf90mpi_get_var_all, but I get an error code of -40.
I want to debug that content, how can I do it?
Please tell us if there is a way to find out what the error code means for each function.
Even a little thing you know will be of great help to me.
Best Regards,
Kihang
E-mail: kyoun at lenovo.com<mailto:kyoun at lenovo.com>
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20210323/802377b8/attachment-0001.html>
More information about the parallel-netcdf
