Regression-tests failing inside a container
Wei-Keng Liao
wkliao at northwestern.edu
Thu Mar 19 13:25:01 CDT 2020
Hi, Carl
Can you try this?
make -i -k check TESTSEQRUN="mpirun -n 1”
or
make -i -k check TESTSEQRUN=“srun -n 1”
i.e. setting the environment variables in the make command line.
> Is there some other setting that I need to make?
TESTOUTDIR can be set to the folder to store the output files produced by
“make check” and “make ptest”. They will be deleted when running “make clean”.
> Also, with the TESTMPIRUN case, does this mean I have to explicitly set the number of MPI procs ("mpirun -n 2" etc.)?
> Is there a way to express the same default that the test-harness would normally use?
When running “make ptest”, the testings are using 2-10 numbers of MPI processes.
When using TESTMPIRUN="mpiexec -n NP”, “NP” will be replaced with the actual
numbers of MPI processes used in the tests. The same for TESTMPIRUN=“srun -n NP”.
Let me know if this answers your questions.
Wei-keng
> On Mar 19, 2020, at 12:48 PM, Carl Ponder <cponder at nvidia.com> wrote:
> I'm building & testing PNetCDF 1.12.1 inside a Docker container, and running under SLURM+PMIx.
> I'm seeing a problem that I hadn't seen when I do this in a "regular" Linux (Ubuntu or CentOS) environment where we used Lmod to manage the libraries.
> For this SLURM/Docker/PMIx arrangement, I invoke the container environment with either of these commands:
> srun --mpi=pmix --container-image=$DOCKER -t 08:00:00 -p batch --pty /bin/bash -i -l
> srun --mpi=none --container-image=$DOCKER -t 08:00:00 -p batch --pty /bin/bash -i -l
> (I'm using interactive sessions until I get all the bugs worked out. Then everything will be scripted.)
> If I run one of the regression-tests manually
> cd test/C
> ./pres_temp_4D_wr
> I get this error
> [circe-n047:12619] OPAL ERROR: Not initialized in file pmix3x_client.c at line 112
> The application appears to have been direct launched using "srun",
> but OMPI was not built with SLURM's PMI support and therefore cannot
> execute. There are several options for building PMI support under
> SLURM, depending upon the SLURM version you are using:
> version 16.05 or later: you can use SLURM's PMIx support. This
> requires that you configure and build SLURM --with-pmix.
> Versions earlier than 16.05: you must use either SLURM's PMI-1 or
> PMI-2 support. SLURM builds PMI-1 by default, or you can manually
> install PMI-2. You must then build Open MPI using --with-pmi pointing
> to the SLURM PMI library location.
> Please configure as appropriate and try again.
> *** An error occurred in MPI_Init
> *** on a NULL communicator
> *** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort,
> *** and potentially your MPI job)
> [circe-n047:12619] Local abort before MPI_INIT completed completed successfully, but am not able to aggregate error messages, and not able to guarantee that all other processes were killed!
> If I use mpirun
> cd test/C
> export OMPI_ALLOW_RUN_AS_ROOT=1
> export OMPI_ALLOW_RUN_AS_ROOT_CONFIRM=1
> export TESTSEQRUN="mpirun -n 1"
> mpirun -n 1 pres_temp_4D_wr
> it looks like it works:
> *** TESTING C pres_temp_4D_wr for writing classic file ------ pass
> and I'd be ok to work this way (although I'd still like to know why the problem showed up in the first place).
> But if I try to roll all this together and put the exports in my build-and-test script
> make -i -k check
> I get the original failure with 100% of the test cases. I'm guessing that the TESTSEQRUN variable is getting cleared somehow. How is it being set, normally?
> I'm also a bit puzzled about the explanation
> TESTSEQRUN Run command (on one MPI process) for "make check" on
> cross-compile environment. Example: "aprun -n 1". [default:
> none]
> TESTMPIRUN MPI run command for "make ptest", [default: mpiexec -n NP]
> I'm not really cross-compiling here, since the Docker environment should look identical on every system I run it on.
> (I'm building & testing in one session on one system here, anyway, so it should be a native compile).
> But the environment could look a little unusual compared with a "regular" Linux system.
> Thanks,
> Carl
> This email message is for the sole use of the intended recipient(s) and may contain confidential information. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply email and destroy all copies of the original message.
More information about the parallel-netcdf
