Building PNetCDF for WRF on ANL LCRC
Wei-Keng Liao wkliao at northwestern.edu
Wed Apr 22 18:27:41 CDT 2020
Hi, Robert
Please send me the following 2 files
config.log and
test/largefile/large_coalesce.log
They may contain information about the errors.
FYI. When building PnetCDF 1.12.1, you need not set those
environment variables. Your configure command can simply
be the following.
./configure --prefix=$WRF_LIBRARIES --enable-large-file-test
Wei-keng
> On Apr 22, 2020, at 3:45 PM, Robert Fritzen <rfritzen1 at niu.edu> wrote:
> Good Afternoon PNetCDF Team,
> I have been trying to compile PNetCDF for use in the WRF model on Bebop (LCRC - ANL) following the following guide for compilation (http://www.hpcadvisorycouncil.com/pdf/WRF_v3.8%20Installation_Best_Practices.pdf), however I am using the GNU compiler suite instead of the intel compiler suite. (The loaded modules on bebop are: gcc/7.3.0-xyzezhj and openmpi/3.1.3-obi56bx)
> My issue is with the large file tests which fails:
> make[4]: Entering directory `/lcrc/project/ACPC/WRF/libs/lib_files/pnetcdf-1.12.1/test/largefile'
> PASS: large_files
> PASS: large_var
> PASS: large_dims_vars_attrs
> PASS: high_dim_var
> PASS: tst_cdf5_begin
> FAIL: large_coalesce
> PASS: bigrecords
> PASS: tst_flarge
> The other required libraries prior to PNetCDF compilation (zlib, szip, libpng, jpeg, jasper, and HDF5 (Parallel)) fully compiled and tested without errors. The export statements I am using are:
> export CC=mpicc
> export CXX=mpicxx
> export FC=mpif90
> export F77=mpif90
> export F90=mpif90
> export OMPI_MPICC=gcc
> export OMPI_MPICXX=g++
> export OMPI_MPIFC=gfortran
> export OMPI_MPIF77=gfortran
> export OMPI_MPIF90=gfortran
> export CFLAGS=’-g -O2 -fPIC’
> export CXXFLAGS=’-g -O2 -fPIC’
> export FFLAGS=’-g -fPIC’
> export FCFLAGS=’-g -fPIC’
> export FLDFLAGS=’-fPIC’
> export F90LDFLAGS=’-fPIC’
> export LDFLAGS=’-fPIC’
> I am running the configure command as such:
> ./configure --prefix=$WRF_LIBRARIES --enable-fortran --enable-large-file-test
> $WRF_LIBRARIES is the path to where my libraries are being installed on LCRC.
> Any assistance to help successfully compile PNetCDF would be appreciated. Thanks!
> Robert
> Robert C. Fritzen
> Ph.D. Student (NIU)
> M.S. Geography & Atmospheric Sciences (NIU, 2017)
> B.S. Atmospheric Sciences (Unv. Illinois Urbana-Champaign, 2013)
> Office Location: Davis Hall 209
