Building PNetCDF for WRF on ANL LCRC
Robert Fritzen rfritzen1 at niu.edu
Wed Apr 22 15:45:54 CDT 2020
Good Afternoon PNetCDF Team,
I have been trying to compile PNetCDF for use in the WRF model on Bebop (LCRC - ANL) following the following guide for compilation (http://www.hpcadvisorycouncil.com/pdf/WRF_v3.8%20Installation_Best_Practices.pdf), however I am using the GNU compiler suite instead of the intel compiler suite. (The loaded modules on bebop are: gcc/7.3.0-xyzezhj and openmpi/3.1.3-obi56bx)
My issue is with the large file tests which fails:
make[4]: Entering directory `/lcrc/project/ACPC/WRF/libs/lib_files/pnetcdf-1.12.1/test/largefile'
PASS: large_files
PASS: large_var
PASS: large_dims_vars_attrs
PASS: high_dim_var
PASS: tst_cdf5_begin
FAIL: large_coalesce
PASS: bigrecords
PASS: tst_flarge
The other required libraries prior to PNetCDF compilation (zlib, szip, libpng, jpeg, jasper, and HDF5 (Parallel)) fully compiled and tested without errors. The export statements I am using are:
export CC=mpicc
export CXX=mpicxx
export FC=mpif90
export F77=mpif90
export F90=mpif90
export OMPI_MPICC=gcc
export OMPI_MPICXX=g++
export OMPI_MPIFC=gfortran
export OMPI_MPIF77=gfortran
export OMPI_MPIF90=gfortran
export CFLAGS='-g -O2 -fPIC'
export CXXFLAGS='-g -O2 -fPIC'
export FFLAGS='-g -fPIC'
export FCFLAGS='-g -fPIC'
export FLDFLAGS='-fPIC'
export F90LDFLAGS='-fPIC'
export LDFLAGS='-fPIC'
I am running the configure command as such:
./configure --prefix=$WRF_LIBRARIES --enable-fortran --enable-large-file-test
$WRF_LIBRARIES is the path to where my libraries are being installed on LCRC.
Any assistance to help successfully compile PNetCDF would be appreciated. Thanks!
Robert
Robert C. Fritzen
Ph.D. Student (NIU)
M.S. Geography & Atmospheric Sciences (NIU, 2017)
B.S. Atmospheric Sciences (Unv. Illinois Urbana-Champaign, 2013)
Office Location: Davis Hall 209
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20200422/dea8a09c/attachment.html>
