problem with using impi 19.0.5
Jim Edwards
jedwards at ucar.edu
Thu Sep 5 20:17:31 CDT 2019
Hi Si,
Can you contact the impi developers and see if this could be the issue and
if we could get a fix quickly if it is.
Wei-keng - thanks!
On Thu, Sep 5, 2019 at 7:06 PM Wei-keng Liao <wkliao at eecs.northwestern.edu>
wrote:
> I guess you are probably hit with the same issue reported in
> https://github.com/pmodels/mpich/pull/3634
> It has been fixed in the MPICH master branch.
> Wei-keng
> > On Sep 5, 2019, at 7:43 PM, Jim Edwards via parallel-netcdf <
> parallel-netcdf at lists.mcs.anl.gov> wrote:
> > I'm using a new system TACC Frontera and having problems on the first
> read - I get:
> > [15065] ADIOI_LUSTRE_IOCONTIG(228): Other I/O error Cannot allocate
> memory
> > : Unknown error occurs in reading file
> > Just wondering if anyone has seen this before?
> > Jim Edwards
> > CESM Software Engineer
> > National Center for Atmospheric Research
> > Boulder, CO
Jim Edwards
Boulder, CO
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20190905/17c0c7f8/attachment.html>
More information about the parallel-netcdf
