problem with using impi 19.0.5
Wei-keng Liao wkliao at eecs.northwestern.edu
Thu Sep 5 20:06:15 CDT 2019
I guess you are probably hit with the same issue reported in
https://github.com/pmodels/mpich/pull/3634
It has been fixed in the MPICH master branch.
Wei-keng
> On Sep 5, 2019, at 7:43 PM, Jim Edwards via parallel-netcdf <parallel-netcdf at lists.mcs.anl.gov> wrote:
> I'm using a new system TACC Frontera and having problems on the first read - I get:
> [15065] ADIOI_LUSTRE_IOCONTIG(228): Other I/O error Cannot allocate memory
>  : Unknown error occurs in reading file
> Just wondering if anyone has seen this before?
> Jim Edwards
> CESM Software Engineer
> National Center for Atmospheric Research
> Boulder, CO
