Problem building PNetCDF 1.12.0 with GCC 7.4.0 and OpenMPI-4.0.2
Nick Papior nickpapior at gmail.com
Sun Oct 20 13:27:27 CDT 2019
Probably this can be fixed by compiling OpenMPI 4 with this configure flag:
--enable-mpi1-compatibility
The variables in questions are marked as removed in MPI-3 standard. So
probably this is why?
Den søn. 20. okt. 2019 kl. 18.41 skrev Carl Ponder via parallel-netcdf <
parallel-netcdf at lists.mcs.anl.gov>:
> I'm seeing this error building PNetCDF 1.12.0 with GCC 7.4.0 and
> OpenMPI-4.0.2:
> make[6]: Entering directory
> '/gpfs/fs1/SHARE/Utils/PNetCDF/1.12.0/GCC-7.4.0_OpenMPI-4.0.2/distro/src/drivers/common'
>   CC       utf8proc.lo
>   CC       mem_alloc.lo
>   CC       dtype_decode.lo
> In file included from dtype_decode.c:16:0:
> dtype_decode.c: In function ‘ncmpii_dtype_decode’:
> dtype_decode.c:390:14: error: expected expression before ‘_Static_assert’
>          case MPI_COMBINER_HVECTOR_INTEGER:
> dtype_decode.c:390:42: error: expected expression before ‘:’ token
> dtype_decode.c:396:43: error: expected expression before ‘:’ token
>          case MPI_COMBINER_HINDEXED_INTEGER:
> dtype_decode.c:462:14: error: expected expression before ‘_Static_assert’
> dtype_decode.c:462:42: error: expected expression before ‘:’ token
> dtype_decode.c:473:14: error: expected expression before ‘_Static_assert’
> dtype_decode.c:473:43: error: expected expression before ‘:’ token
> Makefile:535: recipe for target 'dtype_decode.lo' failed
> make[6]: *** [dtype_decode.lo] Error 1
> make[6]: Leaving directory
> Makefile:452: recipe for target 'all' failed
> make[5]: *** [all] Error 2
> make[5]: Leaving directory
> Makefile:473: recipe for target 'all-recursive' failed
> make[4]: *** [all-recursive] Error 1
> There has been some work done on the src/include/config.h file, that look
> like compatibility fixes for OpenMPI 4.0.2.
> I'm able to build the same OpenMPI & PNetCDF with the PGI 19.9 compiler
> without any problem.
> Do any of you have some settings I can use to get around this?
> I don't mind moving up to GCC 9.* if I have to.
> Thanks in advance,
>                                         Carl
> This email message is for the sole use of the intended recipient(s) and
> may contain confidential information.  Any unauthorized review, use,
> disclosure or distribution is prohibited.  If you are not the intended
> recipient, please contact the sender by reply email and destroy all copies
> of the original message.
Kind regards Nick
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20191020/38b8e7ef/attachment.html>
