Problem building PNetCDF 1.12.0 with GCC 7.4.0 and OpenMPI-4.0.2
Carl Ponder
cponder at nvidia.com
Sun Oct 20 11:36:45 CDT 2019
I'm seeing this error building PNetCDF 1.12.0 with GCC 7.4.0 and
OpenMPI-4.0.2:
make[6]: Entering directory
'/gpfs/fs1/SHARE/Utils/PNetCDF/1.12.0/GCC-7.4.0_OpenMPI-4.0.2/distro/src/drivers/common'
CC utf8proc.lo
CC mem_alloc.lo
CC dtype_decode.lo
In file included from dtype_decode.c:16:0:
dtype_decode.c: In function ‘ncmpii_dtype_decode’:
dtype_decode.c:390:14: error: expected expression before
‘_Static_assert’
case MPI_COMBINER_HVECTOR_INTEGER:
‘_Static_assert’
dtype_decode.c:390:42: error: expected expression before ‘:’ token
dtype_decode.c:396:43: error: expected expression before ‘:’ token
case MPI_COMBINER_HINDEXED_INTEGER:
dtype_decode.c:462:14: error: expected expression before
‘_Static_assert’
‘_Static_assert’
dtype_decode.c:462:42: error: expected expression before ‘:’ token
dtype_decode.c:473:14: error: expected expression before
‘_Static_assert’
‘_Static_assert’
dtype_decode.c:473:43: error: expected expression before ‘:’ token
Makefile:535: recipe for target 'dtype_decode.lo' failed
make[6]: *** [dtype_decode.lo] Error 1
make[6]: Leaving directory
Makefile:452: recipe for target 'all' failed
make[5]: *** [all] Error 2
make[5]: Leaving directory
Makefile:473: recipe for target 'all-recursive' failed
make[4]: *** [all-recursive] Error 1
There has been some work done on the src/include/config.h file, that
look like compatibility fixes for OpenMPI 4.0.2.
I'm able to build the same OpenMPI & PNetCDF with the PGI 19.9 compiler
without any problem.
Do any of you have some settings I can use to get around this?
I don't mind moving up to GCC 9.* if I have to.
Thanks in advance,
Carl
This email message is for the sole use of the intended recipient(s) and may contain
confidential information. Any unauthorized review, use, disclosure or distribution
is prohibited. If you are not the intended recipient, please contact the sender by
reply email and destroy all copies of the original message.
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20191020/3a958d54/attachment.html>
More information about the parallel-netcdf
