error when install PnetCDF
王世柱 wangsz at fio.org.cn
Sun Mar 24 21:31:25 CDT 2019
Hello there,
this is Shizhu from China. When I intall PnetCDF on my server, I follow the following steps:
./configure --prefix=/soa01/home/wangsz/local --with-mpi=/opt/intel/impi/5.0.0.028/intel64/bin/
make check
Then I got the following errors:
make[4]: Leaving directory `/soa01/home/wangsz/local/src/pnetcdf-1.11.0/src/utils/ncvalidator'
make  check-TESTS
make[4]: Entering directory `/soa01/home/wangsz/local/src/pnetcdf-1.11.0/src/utils/ncvalidator'
make[5]: Entering directory `/soa01/home/wangsz/local/src/pnetcdf-1.11.0/src/utils/ncvalidator'
XFAIL: xfail_runs.sh
FAIL: wrap_runs.sh
Testsuite summary for PnetCDF 1.11.0
# TOTAL: 2
# PASS:  0
# SKIP:  0
# XFAIL: 1
# FAIL:  1
# XPASS: 0
# ERROR: 0
See src/utils/ncvalidator/test-suite.log
Please report to parallel-netcdf at mcs.anl.gov
make[5]: *** [test-suite.log] Error 1
make[5]: Leaving directory `/soa01/home/wangsz/local/src/pnetcdf-1.11.0/src/utils/ncvalidator'
make[4]: *** [check-TESTS] Error 2
make[3]: *** [check-am] Error 2
make[3]: Leaving directory `/soa01/home/wangsz/local/src/pnetcdf-1.11.0/src/utils/ncvalidator'
make[2]: *** [check-recursive] Error 1
make[2]: Leaving directory `/soa01/home/wangsz/local/src/pnetcdf-1.11.0/src/utils'
make[1]: *** [check-recursive] Error 1
make[1]: Leaving directory `/soa01/home/wangsz/local/src/pnetcdf-1.11.0/src'
make: *** [check-recursive] Error 1
Enclosed is the log file in src/utils/ncvalidator/test-suite.log
Best,
Shizhu
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20190325/60740af5/attachment.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20190325/60740af5/attachment.ksh>
