conftest.c:11:28: fatal error: ac_nonexistent.h: No such file or directory
Wei-keng Liao
wkliao at eecs.northwestern.edu
Sun Sep 30 12:49:58 CDT 2018
Your config.log shows the configuration was successful.
The error message you are referring is just part of testing
and can be ignored. The true failure of configure command will
print an error message explicitly on screen.
There are many example programs available in all PnetCDF releases,
under folder examples. Command “make ptest” will run them
using 4 MPI processes. You can check the source codes
of these program and use them as template for your own codes.
Wei-keng
> On Sep 29, 2018, at 11:21 PM, Zeinab Salah <zeinabsalah at gmail.com> wrote:
> Hi everyone,
> Please, could you help me? I try to install pnetcdf-1.9.0 with openmpi-3.0.2, but I get this error in config.log: "conftest.c:11:28: fatal error: ac_nonexistent.h: No such file or directory". All the steps of configure, make, tests, check, and ptest are completed without error message, but when I run the model, it doesn't complete the first time step.
> The config.log is attached.
> Thank you in advance.
> Best regards,
> Zeinab
> <config.log>
More information about the parallel-netcdf
