Re: error: ‘MPI_OFFSET’
Latham, Robert J. robl at mcs.anl.gov
Tue Sep 25 09:48:14 CDT 2018
On Tue, 2018-09-25 at 10:28 +0200, Zeinab Salah wrote:
> Hello,
> Please, Could you help me?
> when I try to install pnetcdf-1.7.0  with openmpi-1.2.5, I get this
> error, the config.log is attached.
> The error message:
That's a very old version of openmpi!  It was released December 2007
and I guess is missing some MPI-2.2 features.
for the sake of compatibility, pnetcdf should detect this at configure
time and do something clever.
For the sake of your sanity (because there are a decade of bug fixes
and performance improvements) I would strongly encourage you to upgrade
your MPI implementation.
==rob
> make[1]: Entering directory
> `/home/wrf/CHIMERE/packages_chimere/parallel-netcdf-1.7.0/test'
> make -w -C common
> make[2]: Entering directory
> 1.7.0/test/common'
> make[2]: Nothing to be done for `all'.
> make[2]: Leaving directory
> 1.7.0/test/common'
> make -w -C nc_test
> 1.7.0/test/nc_test'
> /home/wrf/CHIMERE/chimere_lib/openmpi/bin/mpicc  -O -m64
> -mcmodel=medium       -I../../src/lib -I. -I./../common
> -DHAVE_CONFIG_H  -c t_nc.c
> t_nc.c: In function ‘main’:
> t_nc.c:649:48: error: ‘MPI_OFFSET’ undeclared (first use in this
> function)
>          MPI_Reduce(&malloc_size, &sum_size, 1, MPI_OFFSET, MPI_SUM,
> 0, MPI_COMM_WORLD);
> t_nc.c:649:48: note: each undeclared identifier is reported only once
> for each function it appears in
> make[2]: *** [t_nc.o] Error 1
> 1.7.0/test/nc_test'
> make[1]: *** [nc_test] Error 2
> make[1]: Leaving directory
> make: *** [tests-test] Error 2
> installation commands:
> tar -zxvf parallel-netcdf-1.7.0.tar.gz
>    cd parallel-netcdf-1.7.0/
>    export CFLAGS='-O -m64 -mcmodel=medium'
>    export CXXFLAGS='-O -m64 -mcmodel=medium'
>    export FCLAGS='-O -g -m64 -mcmodel=medium'
>    export LDFLAGS='-O -g -mcmodel=medium'
>    export MPICC=/home/wrf/CHIMERE/chimere_lib/openmpi/bin/mpicc
>    export MPICXX=/home/wrf/CHIMERE/chimere_lib/openmpi/bin/mpicxx
>    export MPIF77=/home/wrf/CHIMERE/chimere_lib/openmpi/bin/mpif77
>    export MPIF90=/home/wrf/CHIMERE/chimere_lib/openmpi/bin/mpif90
>    ./configure --prefix=/home/wrf/CHIMERE/chimere_lib/pnetcdf
>    make
>    make tests
> Best regards,
> Zeinab
