install pnetcdf with openmpi with -fdefault-integer-8
Zeinab Salah zeinabsalah at gmail.com
Sun Sep 23 16:44:55 CDT 2018
Hi again,
Sorry, I didn't say that, the version of openmpi is 3.0.2 and pnetcdf is
1.10.0. The installation was successfully completed but the include
directory is not completed. The config.log files of openmpi and pnetcdf are
attached.
the commands of install pnetcdf:
export FC=/usr/bin/gfortran
export F90=/usr/bin/gfortran
export F77=/usr/bin/gfortran
export CC=/usr/bin/gcc
export CXX=/usr/bin/g++
export MPICC=/home/dream/CHIMERE/chimere_lib/openmpi/bin/mpicc
export MPICXX=/home/dream/CHIMERE/chimere_lib/openmpi/bin/mpicxx
export MPIF77=/home/dream/CHIMERE/chimere_lib/openmpi/bin/mpif77
export MPIF90=/home/dream/CHIMERE/chimere_lib/openmpi/bin/mpif90
export CFLAGS='-O -m64 -mcmodel=medium'
export CXXFLAGS='-O -m64 -mcmodel=medium'
export FFLAGS='-O -g -m64 -fno-second-underscore -mcmodel=medium'
export FCLAGS='-O -g -m64 -fno-second-underscore -mcmodel=medium'
export LDFLAGS='-O -g -m64 -fno-second-underscore -mcmodel=medium'
./configure --prefix=/home/dream/CHIMERE/chimere_lib/pnetcdf
--disable-in-place-swap --enable-large-req
--with-mpi=/home/dream/CHIMERE/chimere_lib/openmpi
make
make tests
make check
make ptest
make ptests
make install
Thank you in advance.
Best regards,
Zeinab
‫في السبت، 22 سبتمبر 2018 في 12:03 م تمت كتابة ما يلي بواسطة ‪Zeinab
Salah‬‏ <‪zeinabsalah at gmail.com‬‏>:‬
> Hello,
> I want to install pnetcdf with openmpi with -fdefault-integer-8,  but I
> found the problem of offset, and it installed without error, some files in
> include directory are missing
> my machine is little endian, and operating system is Fedora, and I changed
> many versions of openmpi  and pnetcdf, and give me the same error.
> the commands used to install openmpi:
> export F77=gfortran
> export FC=gfortran
> export CC=gcc
> export CXX=g++
> export CFLAGS=-m64
> export CXXFLAGS=-m64
> export FFLAGS="-m64 -fdefault-integer-8"
> export FCFLAGS="-m64 -fdefault-integer-8"
> ./configure --prefix=$HOME/openmpi --with-mpi-f90-size=medium
> make all
> make install
> Thank you in advance,
> Best regards
> Zeinab
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20180923/f78da189/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20180923/f78da189/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20180923/f78da189/attachment-0003.obj>
