[parallel-netcdf] #37: Build fails with --enable-shared
Bruno Pagani bruno.pagani at astrophysics.eu
Mon May 21 16:57:14 CDT 2018
Not sure why I receive this message only now, but Wei-keng posted a
patch earlier today for this:
--- src/libs/Makefile.am	(revision 3766)
+++ src/libs/Makefile.am	(working copy)
@@ -44,7 +44,7 @@
 libpnetcdf_la_LIBADD += ../binding/f90/libf90.la
 # According to Automake Manual, Section 8.14.3 Mixing Fortran 77 With C and
 # C++, adding $(FLIBS) is necessary
-# libpnetcdf_la_LIBADD += $(FLIBS) $(FCLIBS)
+libpnetcdf_la_LIBADD += $(FLIBS) $(FCLIBS)
 # nodist_EXTRA_libpnetcdf_la_SOURCES += dummyf90.f90
 endif
Bruno
Le 18/05/2018 à 17:07, Srikanth Yalavarthi a écrit :
> [srikanth at discovery parallel-netcdf-1.9.0]$ rpm -q openmpi
> openmpi-1.10.6-2.el7.x86_64
> [srikanth at discovery parallel-netcdf-1.9.0]$ cat /etc/centos-release
> CentOS Linux release 7.4.1708 (Core)
> [srikanth at discovery parallel-netcdf-1.9.0]$ uname -a
> Linux discovery 3.10.0-693.21.1.el7.x86_64 #1 SMP Wed Mar 7 19:03:37
> UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
> Log files attached
> Regards*
> *Srikanth*
> On Fri, May 18, 2018 at 7:59 PM, parallel-netcdf
> <parallel-netcdf at mcs.anl.gov <mailto:parallel-netcdf at mcs.anl.gov>> wrote:
>       Reporter:  srikanth@…       |      Owner:  wkliao
>           Type:  build error      |     Status:  assigned
>       Priority:  major            |  Milestone:
>      Component:  parallel-netcdf  |    Version:  1.9.0
>     Resolution:                   |   Keywords:
>     Changes (by wkliao):
>      * owner:  robl => wkliao
>      * status:  new => assigned
>     Comment:
>      Hi
>      To help us diagnose the problem, please send us the file
>     config.log. It
>      may reveal some info.
>      In addition, please send us the output of command below (it tells the
>      version of OpenMPI).
>      /usr/lib64/openmpi/bin/ompi_info
>     Ticket URL:
>     <http://trac.mcs.anl.gov/projects/parallel-netcdf/ticket/37#comment:1
>     <http://trac.mcs.anl.gov/projects/parallel-netcdf/ticket/37#comment:1>>
>     parallel-netcdf <https://trac.mcs.anl.gov/projects/parallel-netcdf
>     <https://trac.mcs.anl.gov/projects/parallel-netcdf>>
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20180521/9947efbd/attachment.html>
