[parallel-netcdf] #37: Build fails with --enable-shared
Srikanth Yalavarthi srikanth at velankanigroup.com
Fri May 18 10:07:31 CDT 2018
[srikanth at discovery parallel-netcdf-1.9.0]$ rpm -q openmpi
openmpi-1.10.6-2.el7.x86_64
[srikanth at discovery parallel-netcdf-1.9.0]$ cat /etc/centos-release
CentOS Linux release 7.4.1708 (Core)
[srikanth at discovery parallel-netcdf-1.9.0]$ uname -a
Linux discovery 3.10.0-693.21.1.el7.x86_64 #1 SMP Wed Mar 7 19:03:37 UTC
2018 x86_64 x86_64 x86_64 GNU/Linux
Log files attached
Regards
*Srikanth*
On Fri, May 18, 2018 at 7:59 PM, parallel-netcdf <
>   Reporter:  srikanth@…       |      Owner:  wkliao
>       Type:  build error      |     Status:  assigned
>   Priority:  major            |  Milestone:
>  Component:  parallel-netcdf  |    Version:  1.9.0
> Resolution:                   |   Keywords:
> Changes (by wkliao):
>  * owner:  robl => wkliao
>  * status:  new => assigned
> Comment:
>  Hi
>  To help us diagnose the problem, please send us the file config.log. It
>  may reveal some info.
>  In addition, please send us the output of command below (it tells the
>  version of OpenMPI).
>  /usr/lib64/openmpi/bin/ompi_info
> Ticket URL: <http://trac.mcs.anl.gov/projects/parallel-netcdf/
> ticket/37#comment:1>
> parallel-netcdf <https://trac.mcs.anl.gov/projects/parallel-netcdf>
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20180518/4c496446/attachment-0001.html>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20180518/4c496446/attachment-0003.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20180518/4c496446/attachment-0004.bin>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20180518/4c496446/attachment-0005.bin>
