PnetCDF error on cluster
Wei-keng Liao
wkliao at eecs.northwestern.edu
Mon Apr 16 23:25:00 CDT 2018
Using NFS is discouraged for MPI-IO (and PnetCDF as well) applications, because
it requires a special setting in NFS lock daemons to make it work correctly
for MPI-IO.
See ROMIO user guide at ftp://ftp.mcs.anl.gov/pub/romio/users-guide/node12.html <ftp://ftp.mcs.anl.gov/pub/romio/users-guide/node12.html>
If the HPC cluster you are using has a parallel file system, such as Lustre or
OrangeFS, then you should use it.
Wei-keng
> On Apr 16, 2018, at 3:07 AM, o_Orz <x70062924 at qq.com> wrote:
> Hi:
> I runned WRF program on ARM HPC cluster. In the cluster, all nodes share working directory by NFS.
> While using netcdf, I found everything fine except that the performance was poor.
> So I used PnetCDF. On single node, it functioned well. But when it is used in cluster, the netcdf file it generated is wrong and unreadable. I cannot figure oit why. Is it that PnetCDF does not support multi-node application? Is it that I didn't use distribute file system? Or some other reason?
> Best Regards
> Xie Bin
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20180416/870b5f1c/attachment.html>
More information about the parallel-netcdf
