PnetCDF error on cluster
o_Orz x70062924 at qq.com
Mon Apr 16 03:07:21 CDT 2018
Hi:
    I runned WRF program on ARM HPC cluster. In the cluster, all nodes share working directory by NFS.
    While using netcdf, I found everything fine except that the performance was poor.
    So I used PnetCDF. On single node, it functioned well. But when it is used in cluster, the netcdf file it generated is wrong and unreadable. I cannot figure oit why. Is it that PnetCDF does not support multi-node application? Is it that I didn't use distribute file system? Or some other reason?
Best Regards
Xie Bin
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20180416/b0414fbf/attachment.html>
