problem building with openmpi
Jim Edwards
jedwards at ucar.edu
Mon Nov 6 10:16:54 CST 2017
I am trying to build with openmpi/3.0.0 and intel17 and hanging in the build
of pnetcdf.f90.
The make output at the time is:
make[4]: Entering directory
'/glade/u/home/jedwards/src/parallel-netcdf/src/binding/f90'
FC pnetcdf.lo
examining the process I see:
/glade/u/apps/opt/intel/2017u1/compilers_and_libraries/linux/bin/intel64/ifort
-I. -I. -debug minimal -g -O0 -c pnetcdf.f90 -o pnetcdf.o
-I/glade/u/apps/ch/os/usr/include
-L/glade/u/apps/opt/intel/2017u1/compilers_and_libraries/linux/lib/intel64_lin
-L/glade/u/apps/ch/os/usr/lib64 -L/glade/u/apps/ch/os/lib64
-L/glade/u/apps/ch/os/usr/lib -L/glade/u/apps/ch/os/lib
-L/glade/u/apps/ch/opt/openmpi/3.0.0/intel/17.0.1/lib
-Wl,--disable-new-dtags
-Wl,-rpath,/glade/u/apps/opt/intel/2017u1/compilers_and_libraries/linux/lib/intel64_lin
-Wl,-rpath,/glade/u/apps/ch/os/usr/lib64
-Wl,-rpath,/glade/u/apps/ch/os/lib64 -Wl,-rpath,/glade/u/apps/ch/os/usr/lib
-Wl,-rpath,/glade/u/apps/ch/opt/openmpi/3.0.0/intel/17.0.1/lib -lrt -ldl
If I remove all of the -L and -rpath flags and just do:
That completes right away, so the problem seems to have to do with
libtool. Also building with mpt instead of openmpi on the same system
works.
Any ideas?
Jim Edwards
CESM Software Engineer
National Center for Atmospheric Research
Boulder, CO
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20171106/d5ab446a/attachment.html>
More information about the parallel-netcdf
