Tests failures with OpenMPI 2.1
Wei-keng Liao
wkliao at eecs.northwestern.edu
Tue Jun 20 12:32:48 CDT 2017
Hi, Bruno
The root cause of the errors encountered on your x86_64 machine
is also related to an OpenMPI bug recently discovered. Please see
https://github.com/open-mpi/ompi/issues/3695
My suggestion is to wait for OpenMPI developers to fix this
bug in the their future release. Otherwise, you can use
OpenMPI 1.10.6, which does not have the bug, or use MPICH.
Wei-keng
On Jun 20, 2017, at 10:41 AM, Bruno Pagani wrote:
> Le 20/06/2017 à 17:20, Bruno Pagani a écrit :
>> Le 20/06/2017 à 13:13, Bruno Pagani a écrit :
>>> Hi there,
>>> I’m building PNetCDF on ArchLinux, with OpenMPI 2.1 that just landed in
>>> our repos.
>>> Building with 1.10.6 was fine, but with this new version they are
>>> failures during the tests. I’ve uploaded both logs (for the tests part
>>> only, tell me if you need more), first one is with 1.10.6, second one
>>> with 2.1:
>>> https://paste.xinu.at/m-IG5p/
>>> What you want to look for in the second log is “stack smashing detected”.
>>> Thanks for taking a look,
>>> Bruno
>> Additional config/build log: https://paste.xinu.at/o7h/
>> Bruno
> config.log: https://paste.xinu.at/OaTDW/
More information about the parallel-netcdf
