Tests failure when building on i686
Bruno Pagani
bruno.pagani at astrophysics.eu
Tue Jun 20 10:41:40 CDT 2017
Le 20/06/2017 à 17:24, Wei-keng Liao a écrit :
> Hi, Bruno
> The link contains the screen shot of running configure command, not file config.log.
> File config.log is generated after every run of configure command.
> Please make available those files for the failed builds you are seeing.
> i.e. the one with error “stack smashing detected” using OpenMPI 2.1
> and the two one i686.
> Wei-keng
OK sorry I wasn’t sure what you meant. I’m rebuilding them now (my
building chroot has been used for other things in the meantime, so this
file is gone, but the issues are 100% reproducible anyway).
For i686: https://paste.xinu.at/g0zd/
OpenMPI one in the related thread. ;)
Bruno
More information about the parallel-netcdf
