Tests failure when building on i686
Wei-keng Liao wkliao at eecs.northwestern.edu
Tue Jun 20 10:24:00 CDT 2017
Hi, Bruno
The link contains the screen shot of running configure command, not file config.log.
File config.log is generated after every run of configure command.
Please make available those files for the failed builds you are seeing.
i.e. the one with error “stack smashing detected” using OpenMPI 2.1
and the two one i686.
Wei-keng
On Jun 20, 2017, at 10:19 AM, Bruno Pagani wrote:
> Le 20/06/2017 à 17:07, Wei-keng Liao a écrit :
>> Hi, Bruno
>> Could you also make file "config.log" for these builds available?
>> I will take a look.
> Hi Wei-keng,
> Here you go: https://paste.xinu.at/7JUT/
> I’m sending the one for OpenMPI is the corresponding thread too.
> Bruno
