[pnetcdf-devel] [parallel-netcdf] #31: Problem installing pnetcdf on 64 bit Ubuntu machine with intel compilers
Wei-keng Liao
wkliao at eecs.northwestern.edu
Thu Jun 8 10:59:08 CDT 2017
Hi, Steve
The error you encountered is actually a bug in Makefile.in.
The file pnetcdf_pc should be in DIST_GARBAGE, not GARBAGE.
I have committed a fix to the PnetCDF repo. Below is a patch.
Thanks for your testing. Please let me know if the patch works
for you and if you have further questions.
--- Makefile.in (revision 2963)
+++ Makefile.in (working copy)
@@ -28,13 +28,14 @@
benchmarks \
examples
-GARBAGE = pnetcdf_pc
+GARBAGE =
DIST_GARBAGE = config.cache \
config.status \
config.log \
macros.make \
stamp-h \
+ pnetcdf_pc \
pnetcdf.pc \
pnetcdf-config \
check_install
Wei-keng
On Jun 8, 2017, at 4:09 AM, Steve Brenner wrote:
> Wei-keng
> I have done a bit more digging and tried building it again but this time instead of using CC=icc CXX=icpc FC=ifort I now used CC=mpicc CXX=mpicxx MPIF90=mpifort which it picks up from /usr/local/bin. It now completes the build and the two tests (make check and make ptest). When I ran make install it appears to run except for the last few steps where it says
> rm -f pnetcdf.pc
> sed -e "s%INSTALL_PREFIX%/usr/local%g" pnetcdf_pc > pnetcdf.pc
> sed: can't read pnetcdf_pc: No such file or directory
> Makefile:147: recipe for target 'install_PKGCONFIG' failed
> make: *** [install_PKGCONFIG] Error 2
> When I look in /usr/local/include and /usr/local/lib the pnetcdf file are there. I will try running a test code tomorrow.
> Best regards
> Steve Brenner, Professor
> Department of Geography and Environment
> Bar Ilan University
> Ramat Gan, Israel
> Phone: +972 3 5318973
> Secretary: +972 3 531 8340
> Fax: +972 3 7384033
> E-mail: steve.brenner at biu.ac.il
> Web site: geoenv.biu.ac.il/en/Steve_Brenner
> From: Wei-keng Liao <wkliao at eecs.northwestern.edu>
> Sent: Thursday, June 8, 2017 10:09
> To: sbrenner at mail.biu.ac.il
> Cc: parallel-netcdf at mcs.anl.gov
> Subject: Re: [pnetcdf-devel] [parallel-netcdf] #31: Problem installing pnetcdf on 64 bit Ubuntu machine with intel compilers
> I do not have access to the exactly same environment, but just now built
> PnetCDF 1.8.1 on an x86_64 with Ubuntu 14.04, using mpich 3.2. built with
> icc/ifort 16.0.3 and 17.0.2. The build was successful.
> If the build hung at the compile time, then I would guess it most likely
> is an issue of the compiler. Can check your MPI fortran compiler to
> make sure it compiles other F90 programs without problems.
> Wei-keng
> > Reporter: sbrenner@… | Owner: robl
> > Type: defect/bug | Status: new
> > Priority: major | Milestone:
> > Component: parallel-netcdf | Version: 1.8.1
> > Keywords: |
> > I am trying to install pnetcdf on a i7 machine running Ubuntu linux 16.04
> > with the intel 2017 c, c++ and fortran compliers. It configues ok but in
> > the make step it hangs when trying to compile pnetcdf.f90 (no error is
> > returned, it simple is stuck in the compilation step). I have tried both
> > versions 1.8.1 and 1.7.0. Any suggestions?
> > Ticket URL: <http://trac.mcs.anl.gov/projects/parallel-netcdf/ticket/31>
> > parallel-netcdf <https://trac.mcs.anl.gov/projects/parallel-netcdf>
> Parallel netCDF: A Parallel I/O Library for NetCDF File Access
> trac.mcs.anl.gov
> Parallel netCDF: A Parallel I/O Library for NetCDF File Access. Parallel netCDF (PnetCDF) is jointly developed by Northwestern University and Argonne National Laboratory.
> > _______________________________________________
> > pnetcdf-devel mailing list
> > pnetcdf-devel at lists.mcs.anl.gov
> > https://lists.mcs.anl.gov/mailman/listinfo/pnetcdf-devel
More information about the parallel-netcdf
