config.guess failure with IBM/XL
Wei-keng Liao wkliao at eecs.northwestern.edu
Fri Jul 28 11:43:02 CDT 2017
Hi, Carl
Thanks for reporting this. I will make sure the latest versions
of both files appear in the next release.
Wei-keng
On Jul 28, 2017, at 3:50 AM, Carl Ponder wrote:
> I'm building PNetCDF using the IBM/XL compilers for the Power architecture.
> I got this error message:
> checking build system type... ./scripts/config.guess: unable to guess system type
> This script, last modified 2011-10-01, has failed to recognize
> the operating system you are using. It is advised that you
> download the most up to date version of the config scripts from
>   http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess;hb=HEAD
> and
>   http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.sub;hb=HEAD
> If the version you run (./scripts/config.guess) is already up to date, please
> send the following data and any information you think might be
> pertinent to <config-patches at gnu.org> in order to provide the needed
> information to handle your system.
> config.guess timestamp = 2011-10-01
> uname -m = ppc64le
> uname -r = 3.10.0-514.6.2.el7.ppc64le
> uname -s = Linux
> uname -v = #1 SMP Fri Feb 17 19:22:37 EST 2017
> /usr/bin/uname -p = ppc64le
> /bin/uname -X     =
> hostinfo               =
> /bin/universe          =
> /usr/bin/arch -k       =
> /bin/arch              = ppc64le
> /usr/bin/oslevel       =
> /usr/convex/getsysinfo =
> UNAME_MACHINE = ppc64le
> UNAME_RELEASE = 3.10.0-514.6.2.el7.ppc64le
> UNAME_SYSTEM  = Linux
> UNAME_VERSION = #1 SMP Fri Feb 17 19:22:37 EST 2017
> configure: error: cannot guess build type; you must specify one
> I got the build to work by using newer copies of the config.guess & config.sub.
> The versions bundled in the latest PNetCDF (1.8.1) look pretty old (2011), can you update them in the next release?
> Thanks,
>                   Carl Ponder
>                   NVIDIA Developer Technology
> This email message is for the sole use of the intended recipient(s) and may contain confidential information.  Any unauthorized review, use, disclosure or distribution is prohibited.  If you are not the intended recipient, please contact the sender by reply email and destroy all copies of the original message.
