config.guess failure with IBM/XL
Carl Ponder cponder at nvidia.com
Fri Jul 28 03:50:02 CDT 2017
I'm building PNetCDF using the IBM/XL compilers for the Power architecture.
I got this error message:
    *checking build system type... ./scripts/config.guess: unable to
    guess system type*
    This script, last modified 2011-10-01, has failed to recognize
    the operating system you are using. It is advised that you
    download the most up to date version of the config scripts from
    http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.guess;hb=HEAD
    and
    http://git.savannah.gnu.org/gitweb/?p=config.git;a=blob_plain;f=config.sub;hb=HEAD
    If the version you run (./scripts/config.guess) is already up to
    date, please
    send the following data and any information you think might be
    pertinent to <config-patches at gnu.org> in order to provide the needed
    information to handle your system.
    *config.guess timestamp = 2011-10-01*
    uname -m = ppc64le
    uname -r = 3.10.0-514.6.2.el7.ppc64le
    uname -s = Linux
    uname -v = #1 SMP Fri Feb 17 19:22:37 EST 2017
    /usr/bin/uname -p = ppc64le
    /bin/uname -X     =
    hostinfo               =
    /bin/universe          =
    /usr/bin/arch -k       =
    /bin/arch              = ppc64le
    /usr/bin/oslevel       =
    /usr/convex/getsysinfo =
    UNAME_MACHINE = ppc64le
    UNAME_RELEASE = 3.10.0-514.6.2.el7.ppc64le
    UNAME_SYSTEM  = Linux
    UNAME_VERSION = #1 SMP Fri Feb 17 19:22:37 EST 2017
    configure: error: cannot guess build type; you must specify one
I got the build to work by using newer copies of the config.guess &
config.sub.
The versions bundled in the latest PNetCDF (1.8.1) look pretty old
(2011), can you update them in the next release?
                   Carl Ponder
                   NVIDIA Developer Technology
This email message is for the sole use of the intended recipient(s) and may contain
confidential information.  Any unauthorized review, use, disclosure or distribution
is prohibited.  If you are not the intended recipient, please contact the sender by
reply email and destroy all copies of the original message.
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20170728/c86d1d08/attachment.html>
