Release of PnetCDF 1.9.0
Wei-keng Liao
wkliao at eecs.northwestern.edu
Wed Dec 20 17:13:25 CST 2017
If GNU 7.2.1 is a suspect, would you like to try an earlier
version of GNU compilers to verify?
Wei-keng
On Dec 20, 2017, at 5:01 PM, Bruno Pagani wrote:
> Le 20/12/2017 à 23:50, Wei-keng Liao a écrit :
>> I just built an OpenMPI 3.0.0 with GNU 6.2.0 compilers on a Redhat but
>> could not reproduce the errors you are seeing.
> The issue arise with both OpenMPI 2.1.1 and 3.0.0. I would rather expect
> GNU 7.2.1 to be the culprit here.
>> To check whether the problem is OpenMPI related, could you try
>> using MPICH and see if the errors go away?
> Will take me some time as MPICH is not currently available on ArchLinux
> (this is on my TL, but not reachable in a foreseeable future), so I
> won’t be able to test it within our building system. But if I can build
> it locally and try with that maybe that could do it (I would need to
> reproduce the error outside our building system first, but that should
> be straight away).
> I’ll keep you updated, but expect some weeks before I do.
> Regards,
> Bruno
More information about the parallel-netcdf
