Release of PnetCDF 1.9.0
Wei-keng Liao wkliao at eecs.northwestern.edu
Wed Dec 20 11:03:15 CST 2017
Please provide the file "config.log" generated by the configure command.
FYI. PnetCDF 1.9.0 has been tested fine against GNU compilers up to 6.2.0.
Wei-keng
On Dec 19, 2017, at 5:23 PM, Bruno Pagani wrote:
> Hi,
> Le 19/12/2017 à 23:47, Wei-keng Liao a écrit :
>> Hello to the PnetCDF community,
>> We are pleased to announce the software release of PnetCDF 1.9.0.
>> The source code package is now available for download.
>> http://cucis.ece.northwestern.edu/projects/PnetCDF/download.html
>> Detailed changes made since 1.8.1 can be found in the release note,
>> a file named RELEASE_NOTES in the release package, as well as the URL below.
>> https://trac.mcs.anl.gov/projects/parallel-netcdf/wiki/ReleaseNotes-1.9.0
>> Please report problems encountered to this mailing list.
>> Best wishes and happy holidays !
>> Wei-keng Liao
> I’m likely doing something wrong, but when compiling with
> --enabled-shared, I’m facing the following errors:
> ../../../src/libs/.libs/libpnetcdf.so: undefined reference to
> `_gfortran_shape_4'
> `_gfortran_os_error'
> `_gfortran_runtime_error_at'
> `_gfortran_runtime_error'
> `_gfortran_internal_unpack'
> `_gfortran_internal_pack'
> `_gfortran_string_len_trim'
> This is the configuration output:
>    parallel-netcdf Version 1.9.0
>    Features:  Build static libraries                      - yes
>               Build shared libraries                      - yes
>               Build Fortran APIs                          - yes
>               Build C++ APIs                              - yes
>    Compilers: MPICC    = /usr/bin/mpicc
>               MPICXX   = /usr/bin/mpicxx
>               MPIF77   = /usr/bin/mpif77
>               MPIF90   = /usr/bin/mpif90
>               CFLAGS   = -march=x86-64 -mtune=generic -O2 -pipe
> -fstack-protector-strong -fno-plt
>               CPPFLAGS = -D_FORTIFY_SOURCE=2
>               CXXFLAGS = -march=x86-64 -mtune=generic -O2 -pipe
>               FFLAGS   = -g -O2
>               FCFLAGS  = -g -O2
>               LDFLAGS  = -Wl,-O1,--sort-common,--as-needed,-z,relro,-z,now
> And I’m using gfortran 7.2.1. Obviously building only the static library
> works, but I thought this new version was also about being able to build
> the shared version. ;)
> Regarding the static library, I have two tests failures though:
> FAIL: mcoll_testf77
> FAIL: mcoll_testf
> Will come back with more logs regarding those tomorrow.
> Regards,
> Bruno
