Release of PnetCDF 1.9.0
Bruno Pagani
bruno.pagani at astrophysics.eu
Tue Dec 19 17:23:00 CST 2017
Le 19/12/2017 à 23:47, Wei-keng Liao a écrit :
> Hello to the PnetCDF community,
> We are pleased to announce the software release of PnetCDF 1.9.0.
> The source code package is now available for download.
> http://cucis.ece.northwestern.edu/projects/PnetCDF/download.html
> Detailed changes made since 1.8.1 can be found in the release note,
> a file named RELEASE_NOTES in the release package, as well as the URL below.
> https://trac.mcs.anl.gov/projects/parallel-netcdf/wiki/ReleaseNotes-1.9.0
> Please report problems encountered to this mailing list.
> Best wishes and happy holidays !
> Wei-keng Liao
I’m likely doing something wrong, but when compiling with
--enabled-shared, I’m facing the following errors:
../../../src/libs/.libs/libpnetcdf.so: undefined reference to
`_gfortran_shape_4'
`_gfortran_os_error'
`_gfortran_runtime_error_at'
`_gfortran_runtime_error'
`_gfortran_internal_unpack'
`_gfortran_internal_pack'
`_gfortran_string_len_trim'
This is the configuration output:
parallel-netcdf Version 1.9.0
Features: Build static libraries - yes
Build shared libraries - yes
Build Fortran APIs - yes
Build C++ APIs - yes
Compilers: MPICC = /usr/bin/mpicc
MPICXX = /usr/bin/mpicxx
MPIF77 = /usr/bin/mpif77
MPIF90 = /usr/bin/mpif90
CFLAGS = -march=x86-64 -mtune=generic -O2 -pipe
-fstack-protector-strong -fno-plt
CPPFLAGS = -D_FORTIFY_SOURCE=2
CXXFLAGS = -march=x86-64 -mtune=generic -O2 -pipe
FFLAGS = -g -O2
FCFLAGS = -g -O2
LDFLAGS = -Wl,-O1,--sort-common,--as-needed,-z,relro,-z,now
And I’m using gfortran 7.2.1. Obviously building only the static library
works, but I thought this new version was also about being able to build
the shared version. ;)
Regarding the static library, I have two tests failures though:
FAIL: mcoll_testf77
FAIL: mcoll_testf
Will come back with more logs regarding those tomorrow.
Bruno
More information about the parallel-netcdf
