Unable to pass all the tests with pnetcdf 1.6.1, Intel 15.0.3.048 and Mvapich2 2.1
Wei-keng Liao wkliao at eecs.northwestern.edu
Mon Sep 21 14:21:15 CDT 2015
It is strange that the test failed for Lustre.
The error message says some variables defined across MPI processes are not consistent.
Could you run this benchmark with safe mode on? by setting the environment variable
PNETCDF_SAFE_MODE to 1 before the run. This will print more error messages, such as
which variables are inconsistent and at what offsets.
Wei-keng
On Sep 21, 2015, at 1:31 PM, Craig Tierney - NOAA Affiliate wrote:
> Rob and Wei-keng,
> Thanks for you help on this problem.  Rob - The patch seems to work.  I had to hand apply it but now the pnetcdf tests (mostly) complete successfully.  The FLASH-IO benchmark is failing when Lustre is used.  It completes successfully when Panasas is used.  The error code that is returned by nfmpi_enddef is -262.   The description for this error is:
> #define NC_EMULTIDEFINE_VAR_BEGIN       (-262) /**< inconsistent variable file begin offset (internal use) */
> [root at Jet:fe7 FLASH-IO]# mpiexec.hydra -n 4 ./flash_benchmark_io /pan2/jetmgmt/Craig.Tierney/pan_flash_io_test_
>  Here:           0
>  Here:           0
>  Here:           0
>  Here:           0
>  number of guards      :             4
>  number of blocks      :            80
>  number of variables   :            24
>  checkpoint time       :            12.74  sec
>         max header     :             0.88  sec
>         max unknown    :            11.83  sec
>         max close      :             0.53  sec
>         I/O amount     :           242.30  MiB
>  plot no corner        :             2.38  sec
>         max header     :             0.59  sec
>         max unknown    :             1.78  sec
>         max close      :             0.22  sec
>         I/O amount     :            20.22  MiB
>  plot    corner        :             2.52  sec
>         max header     :             0.81  sec
>         max unknown    :             1.51  sec
>         max close      :             0.96  sec
>         I/O amount     :            24.25  MiB
>  File base name        : /pan2/jetmgmt/Craig.Tierney/pan_flash_io_test_
>    file striping count :             0
>    file striping size  :     301346992     bytes
>  Total I/O amount      :           286.78  MiB
>  nproc    array size      exec (sec)   bandwidth (MiB/s)
>     4    16 x  16 x  16     17.64       16.26
> [root at Jet:fe7 FLASH-IO]# mpiexec.hydra -n 4 ./flash_benchmark_io /lfs2/jetmgmt/Craig.Tierney/lfs_flash_io_test_
>  Here:        -262
>  Here:        -262
>  Here:        -262
>  nfmpi_enddef
>  (Internal error) beginning file offset of this variable is inconsistent among p
>  r
>  nfmpi_enddef
>  r
>  nfmpi_enddef
>  r
>  Here:           0
> [cli_1]: aborting job:
> application called MPI_Abort(MPI_COMM_WORLD, -1) - process 1
> [cli_3]: [cli_2]: aborting job:
> application called MPI_Abort(MPI_COMM_WORLD, -1) - process 3
> aborting job:
> application called MPI_Abort(MPI_COMM_WORLD, -1) - process 2
> =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> =   PID 16702 RUNNING AT fe7
> =   EXIT CODE: 255
> =   CLEANING UP REMAINING PROCESSES
> =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> Thanks,
> Craig
> On Mon, Sep 21, 2015 at 8:30 AM, Rob Latham <robl at mcs.anl.gov> wrote:
> On 09/20/2015 03:44 PM, Craig Tierney - NOAA Affiliate wrote:
> Wei-keng,
> I tried your test code on a different system, and I found it worked with
> Intel+mvapich2 (2.1rc1).  That system was using Panasas and I was
> testing on Lustre.  I then tried Panasas on the original machine
> (supports both Panasas and Lustre) and I got the correct behavior.
> So the problem somehow related to Lustre.  We are using the 2.5.37.ddn
> client.   Unless you have an obvious answer, I will open this with DDN
> tomorrow.
> Ah, bet I know why this is!
> the Lustre driver and (some versions of the) Panasas driver set their fs-specific hints by opening the file, setting some ioctls, then continuing on without deleting the file.
>  In the common case, when we expect the file to show up, no one notices or cares, but in MPI_MODE_EXCL or some other restrictive flags, the file gets created when we did not expect it to -- and that's part of the reason this bug lived on so long.
> I fixed this by moving file manipulations out of the hint parsing path and into the open path (after we check permissions and flags)
> Relevant commit: https://trac.mpich.org/projects/mpich/changeset/92f1c69f0de87f9
> See more details from Darshan, OpenMPI, and MPICH here:
> - https://trac.mpich.org/projects/mpich/ticket/2261
> - https://github.com/open-mpi/ompi/issues/158
> - http://lists.mcs.anl.gov/pipermail/darshan-users/2015-February/000256.html
> ==rob
> Thanks,
> Craig
> On Sun, Sep 20, 2015 at 2:36 PM, Craig Tierney - NOAA Affiliate
> <craig.tierney at noaa.gov <mailto:craig.tierney at noaa.gov>> wrote:
>     Wei-keng,
>     Thanks for the test case.  Here is what I get using a set of
>     compilers and MPI stacks.  I was expecting that mvapich2 1.8 and 2.1
>     would behave differently.
>     What versions of MPI do you test internally?
>     Craig
>     Testing intel+impi
>     Currently Loaded Modules:
>        1) newdefaults   2) intel/15.0.3.187 <http://15.0.3.187>   3)
>     impi/5.1.1.109 <http://5.1.1.109>
>     Error at line 22: File does not exist, error stack:
>     ADIOI_NFS_OPEN(69): File /lfs3/jetmgmt/Craig.Tierney/tooth-fairy.nc
>     <http://tooth-fairy.nc> does not exist
>     Testing intel+mvapich2 2.1
>     mvapich2/2.1
>     file was opened: /lfs3/jetmgmt/Craig.Tierney/tooth-fairy.nc
>     Testing intel+mvapich2 1.8
>     mvapich2/1.8
>     Testing pgi+mvapich2 2.1
>        1) newdefaults   2) pgi/15.3   3) mvapich2/2.1
>     Testing pgi+mvapich2 1.8
>        1) newdefaults   2) pgi/15.3   3) mvapich2/1.8
>     Craig
>     On Sun, Sep 20, 2015 at 1:43 PM, Wei-keng Liao
>     <wkliao at eecs.northwestern.edu <mailto:wkliao at eecs.northwestern.edu>>
>     wrote:
>         In that case, it is likely mvapich does not perform correctly.
>         In PnetCDF, when NC_NOWRITE is used in a call to ncmpi_open,
>         PnetCDF calls a MPI_File_open with the open flag set to
>         MPI_MODE_RDONLY. See
>         http://trac.mcs.anl.gov/projects/parallel-netcdf/browser/tags/v1-6-1/src/lib/mpincio.c#L322
>         Maybe test this with a simple MPI-IO program below.
>         It prints error messages like
>              Error at line 15: File does not exist, error stack:
>              ADIOI_UFS_OPEN(69): File tooth-fairy.nc
>         But, no file should be created.
>         #include <stdio.h>
>         #include <unistd.h> /* unlink() */
>         #include <mpi.h>
>         int main(int argc, char **argv) {
>              int err;
>              MPI_File fh;
>              MPI_Init(&argc, &argv);
>              /* delete "tooth-fairy.nc <http://tooth-fairy.nc>" and
>         ignore the error */
>              unlink("tooth-fairy.nc <http://tooth-fairy.nc>");
>              err = MPI_File_open(MPI_COMM_WORLD, "tooth-fairy.nc
>         <http://tooth-fairy.nc>", MPI_MODE_RDONLY, MPI_INFO_NULL, &fh);
>              if (err != MPI_SUCCESS) {
>                  int errorStringLen;
>                  char errorString[MPI_MAX_ERROR_STRING];
>                  MPI_Error_string(err, errorString, &errorStringLen);
>                  printf("Error at line %d: %s\n",__LINE__, errorString);
>              else
>                  MPI_File_close(&fh);
>              MPI_Finalize();
>              return 0;
>         Wei-keng
>         On Sep 20, 2015, at 1:51 PM, Craig Tierney - NOAA Affiliate wrote:
>          > Wei-keng,
>          > I always run distclean before I try to build the code.  The
>         first test failing is nc_test.  The problem seems to be in this
>         test:
>          >    err = ncmpi_open(comm, "tooth-fairy.nc
>         <http://tooth-fairy.nc>", NC_NOWRITE, info, &ncid);/* should fail */
>          >     IF (err == NC_NOERR)
>          >         error("ncmpi_open of nonexistent file should have
>         failed");
>          >     IF (err != NC_ENOENT)
>         returned NC_ENOENT");
>          >     else {
>          >         /* printf("Expected error message complaining: \"File
>         tooth-fairy.nc <http://tooth-fairy.nc> does not exist\"\n"); */
>          >         nok++;
>          > A zero length tooth-fairy.nc <http://tooth-fairy.nc> file is
>         being created, and I don't think that is supposed to happen.
>         That would mean that the mode NC_NOWRITE is not being honored by
>         MPI_IO.  I will look at this more tomorrow and try to craft a
>         short example.
>          > Craig
>          > On Sun, Sep 20, 2015 at 10:23 AM, Wei-keng Liao
>         <mailto:wkliao at eecs.northwestern.edu>> wrote:
>          > Hi, Craig
>          > Your config.log looks fine to me.
>          > Some of your error messages are supposed to report errors of
>         opening
>          > a non-existing file, but report a different error code,
>         meaning the
>          > file does exist. I suspect it may be because of residue files.
>          > Could you do a clean rebuild with the following commands?
>          >     % make -s distclean
>          >     % ./configure --prefix=/apps/pnetcdf/1.6.1-intel-mvapich2
>          >     % make -s -j8
>          >     % make -s check
>          > If the problem persists, then it might be because mvapich.
>          > Wei-keng
> Rob Latham
> Mathematics and Computer Science Division
> Argonne National Lab, IL USA
