Unable to pass all the tests with pnetcdf 1.6.1, Intel 15.0.3.048 and Mvapich2 2.1
Craig Tierney - NOAA Affiliate
craig.tierney at noaa.gov
Mon Sep 21 13:31:44 CDT 2015
Rob and Wei-keng,
Thanks for you help on this problem. Rob - The patch seems to work. I had
to hand apply it but now the pnetcdf tests (mostly) complete successfully.
The FLASH-IO benchmark is failing when Lustre is used. It completes
successfully when Panasas is used. The error code that is returned by
nfmpi_enddef is -262. The description for this error is:
#define NC_EMULTIDEFINE_VAR_BEGIN (-262) /**< inconsistent variable
file begin offset (internal use) */
[root at Jet:fe7 FLASH-IO]# mpiexec.hydra -n 4 ./flash_benchmark_io
/pan2/jetmgmt/Craig.Tierney/pan_flash_io_test_
Here: 0
Here: 0
Here: 0
Here: 0
number of guards : 4
number of blocks : 80
number of variables : 24
checkpoint time : 12.74 sec
max header : 0.88 sec
max unknown : 11.83 sec
max close : 0.53 sec
I/O amount : 242.30 MiB
plot no corner : 2.38 sec
max header : 0.59 sec
max unknown : 1.78 sec
max close : 0.22 sec
I/O amount : 20.22 MiB
plot corner : 2.52 sec
max header : 0.81 sec
max unknown : 1.51 sec
max close : 0.96 sec
I/O amount : 24.25 MiB
File base name : /pan2/jetmgmt/Craig.Tierney/pan_flash_io_test_
file striping count : 0
file striping size : 301346992 bytes
Total I/O amount : 286.78 MiB
nproc array size exec (sec) bandwidth (MiB/s)
4 16 x 16 x 16 17.64 16.26
/lfs2/jetmgmt/Craig.Tierney/lfs_flash_io_test_
Here: -262
Here: -262
Here: -262
nfmpi_enddef
(Internal error) beginning file offset of this variable is inconsistent
among p
r
nfmpi_enddef
among p
r
nfmpi_enddef
among p
r
Here: 0
[cli_1]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, -1) - process 1
[cli_3]: [cli_2]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, -1) - process 3
aborting job:
application called MPI_Abort(MPI_COMM_WORLD, -1) - process 2
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= PID 16702 RUNNING AT fe7
= EXIT CODE: 255
= CLEANING UP REMAINING PROCESSES
= YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
Craig
On Mon, Sep 21, 2015 at 8:30 AM, Rob Latham <robl at mcs.anl.gov> wrote:
> On 09/20/2015 03:44 PM, Craig Tierney - NOAA Affiliate wrote:
>> Wei-keng,
>> I tried your test code on a different system, and I found it worked with
>> Intel+mvapich2 (2.1rc1). That system was using Panasas and I was
>> testing on Lustre. I then tried Panasas on the original machine
>> (supports both Panasas and Lustre) and I got the correct behavior.
>> So the problem somehow related to Lustre. We are using the 2.5.37.ddn
>> client. Unless you have an obvious answer, I will open this with DDN
>> tomorrow.
> Ah, bet I know why this is!
> the Lustre driver and (some versions of the) Panasas driver set their
> fs-specific hints by opening the file, setting some ioctls, then continuing
> on without deleting the file.
> In the common case, when we expect the file to show up, no one notices or
> cares, but in MPI_MODE_EXCL or some other restrictive flags, the file gets
> created when we did not expect it to -- and that's part of the reason this
> bug lived on so long.
> I fixed this by moving file manipulations out of the hint parsing path and
> into the open path (after we check permissions and flags)
> Relevant commit:
> https://trac.mpich.org/projects/mpich/changeset/92f1c69f0de87f9
> See more details from Darshan, OpenMPI, and MPICH here:
> - https://trac.mpich.org/projects/mpich/ticket/2261
> - https://github.com/open-mpi/ompi/issues/158
> http://lists.mcs.anl.gov/pipermail/darshan-users/2015-February/000256.html
> ==rob
> Thanks,
>> Craig
>> On Sun, Sep 20, 2015 at 2:36 PM, Craig Tierney - NOAA Affiliate
>> <craig.tierney at noaa.gov <mailto:craig.tierney at noaa.gov>> wrote:
>> Wei-keng,
>> Thanks for the test case. Here is what I get using a set of
>> compilers and MPI stacks. I was expecting that mvapich2 1.8 and 2.1
>> would behave differently.
>> What versions of MPI do you test internally?
>> Craig
>> Testing intel+impi
>> Currently Loaded Modules:
>> 1) newdefaults 2) intel/15.0.3.187 <http://15.0.3.187> 3)
>> impi/5.1.1.109 <http://5.1.1.109>
>> Error at line 22: File does not exist, error stack:
>> ADIOI_NFS_OPEN(69): File /lfs3/jetmgmt/Craig.Tierney/tooth-fairy.nc
>> <http://tooth-fairy.nc> does not exist
>> Testing intel+mvapich2 2.1
>> mvapich2/2.1
>> file was opened: /lfs3/jetmgmt/Craig.Tierney/tooth-fairy.nc
>> Testing intel+mvapich2 1.8
>> mvapich2/1.8
>> Testing pgi+mvapich2 2.1
>> 1) newdefaults 2) pgi/15.3 3) mvapich2/2.1
>> Testing pgi+mvapich2 1.8
>> 1) newdefaults 2) pgi/15.3 3) mvapich2/1.8
>> Craig
>> On Sun, Sep 20, 2015 at 1:43 PM, Wei-keng Liao
>> <wkliao at eecs.northwestern.edu <mailto:wkliao at eecs.northwestern.edu>>
>> wrote:
>> In that case, it is likely mvapich does not perform correctly.
>> In PnetCDF, when NC_NOWRITE is used in a call to ncmpi_open,
>> PnetCDF calls a MPI_File_open with the open flag set to
>> MPI_MODE_RDONLY. See
>> http://trac.mcs.anl.gov/projects/parallel-netcdf/browser/tags/v1-6-1/src/lib/mpincio.c#L322
>> Maybe test this with a simple MPI-IO program below.
>> It prints error messages like
>> Error at line 15: File does not exist, error stack:
>> ADIOI_UFS_OPEN(69): File tooth-fairy.nc
>> But, no file should be created.
>> #include <stdio.h>
>> #include <unistd.h> /* unlink() */
>> #include <mpi.h>
>> int main(int argc, char **argv) {
>> int err;
>> MPI_File fh;
>> MPI_Init(&argc, &argv);
>> /* delete "tooth-fairy.nc <http://tooth-fairy.nc>" and
>> ignore the error */
>> unlink("tooth-fairy.nc <http://tooth-fairy.nc>");
>> err = MPI_File_open(MPI_COMM_WORLD, "tooth-fairy.nc
>> <http://tooth-fairy.nc>", MPI_MODE_RDONLY, MPI_INFO_NULL, &fh);
>> if (err != MPI_SUCCESS) {
>> int errorStringLen;
>> char errorString[MPI_MAX_ERROR_STRING];
>> MPI_Error_string(err, errorString, &errorStringLen);
>> printf("Error at line %d: %s\n",__LINE__, errorString);
>> else
>> MPI_File_close(&fh);
>> MPI_Finalize();
>> return 0;
>> Wei-keng
>> On Sep 20, 2015, at 1:51 PM, Craig Tierney - NOAA Affiliate wrote:
>> > Wei-keng,
>> > I always run distclean before I try to build the code. The
>> first test failing is nc_test. The problem seems to be in this
>> test:
>> > err = ncmpi_open(comm, "tooth-fairy.nc
>> <http://tooth-fairy.nc>", NC_NOWRITE, info, &ncid);/* should
>> fail */
>> > IF (err == NC_NOERR)
>> > error("ncmpi_open of nonexistent file should have
>> failed");
>> > IF (err != NC_ENOENT)
>> returned NC_ENOENT");
>> > else {
>> > /* printf("Expected error message complaining: \"File
>> tooth-fairy.nc <http://tooth-fairy.nc> does not exist\"\n"); */
>> > nok++;
>> > A zero length tooth-fairy.nc <http://tooth-fairy.nc> file is
>> being created, and I don't think that is supposed to happen.
>> That would mean that the mode NC_NOWRITE is not being honored by
>> MPI_IO. I will look at this more tomorrow and try to craft a
>> short example.
>> > Craig
>> > On Sun, Sep 20, 2015 at 10:23 AM, Wei-keng Liao
>> <mailto:wkliao at eecs.northwestern.edu>> wrote:
>> > Hi, Craig
>> > Your config.log looks fine to me.
>> > Some of your error messages are supposed to report errors of
>> opening
>> > a non-existing file, but report a different error code,
>> meaning the
>> > file does exist. I suspect it may be because of residue files.
>> > Could you do a clean rebuild with the following commands?
>> > % make -s distclean
>> > % ./configure --prefix=/apps/pnetcdf/1.6.1-intel-mvapich2
>> > % make -s -j8
>> > % make -s check
>> > If the problem persists, then it might be because mvapich.
>> > Wei-keng
> Rob Latham
> Mathematics and Computer Science Division
> Argonne National Lab, IL USA
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20150921/c9607fe1/attachment.html>
More information about the parallel-netcdf
