Unable to pass all the tests with pnetcdf 1.6.1, Intel 15.0.3.048 and Mvapich2 2.1
Wei-keng Liao
wkliao at eecs.northwestern.edu
Sun Sep 20 14:43:59 CDT 2015
In that case, it is likely mvapich does not perform correctly.
In PnetCDF, when NC_NOWRITE is used in a call to ncmpi_open,
PnetCDF calls a MPI_File_open with the open flag set to MPI_MODE_RDONLY. See
http://trac.mcs.anl.gov/projects/parallel-netcdf/browser/tags/v1-6-1/src/lib/mpincio.c#L322
Maybe test this with a simple MPI-IO program below.
It prints error messages like
Error at line 15: File does not exist, error stack:
ADIOI_UFS_OPEN(69): File tooth-fairy.nc does not exist
But, no file should be created.
#include <stdio.h>
#include <unistd.h> /* unlink() */
#include <mpi.h>
int main(int argc, char **argv) {
int err;
MPI_File fh;
MPI_Init(&argc, &argv);
/* delete "tooth-fairy.nc" and ignore the error */
unlink("tooth-fairy.nc");
err = MPI_File_open(MPI_COMM_WORLD, "tooth-fairy.nc", MPI_MODE_RDONLY, MPI_INFO_NULL, &fh);
if (err != MPI_SUCCESS) {
int errorStringLen;
char errorString[MPI_MAX_ERROR_STRING];
MPI_Error_string(err, errorString, &errorStringLen);
printf("Error at line %d: %s\n",__LINE__, errorString);
else
MPI_File_close(&fh);
MPI_Finalize();
return 0;
Wei-keng
On Sep 20, 2015, at 1:51 PM, Craig Tierney - NOAA Affiliate wrote:
> Wei-keng,
> I always run distclean before I try to build the code. The first test failing is nc_test. The problem seems to be in this test:
> err = ncmpi_open(comm, "tooth-fairy.nc", NC_NOWRITE, info, &ncid);/* should fail */
> IF (err == NC_NOERR)
> error("ncmpi_open of nonexistent file should have failed");
> IF (err != NC_ENOENT)
> error("ncmpi_open of nonexistent file should have returned NC_ENOENT");
> else {
> /* printf("Expected error message complaining: \"File tooth-fairy.nc does not exist\"\n"); */
> nok++;
> A zero length tooth-fairy.nc file is being created, and I don't think that is supposed to happen. That would mean that the mode NC_NOWRITE is not being honored by MPI_IO. I will look at this more tomorrow and try to craft a short example.
> Craig
> On Sun, Sep 20, 2015 at 10:23 AM, Wei-keng Liao <wkliao at eecs.northwestern.edu> wrote:
> Hi, Craig
> Your config.log looks fine to me.
> Some of your error messages are supposed to report errors of opening
> a non-existing file, but report a different error code, meaning the
> file does exist. I suspect it may be because of residue files.
> Could you do a clean rebuild with the following commands?
> % make -s distclean
> % ./configure --prefix=/apps/pnetcdf/1.6.1-intel-mvapich2
> % make -s -j8
> % make -s check
> If the problem persists, then it might be because mvapich.
> Wei-keng
More information about the parallel-netcdf
