input/output errors from "make check"
Wei-keng Liao
wkliao at eecs.northwestern.edu
Thu May 28 10:20:04 CDT 2015
Hi, Carl
The error message "=>> PBS: job killed: walltime 3636 exceeded limit 3600"
means the time allocated in your job submitted to the PBS queue is 3600 seconds, and the
job ran more than that limit and was killed by the system.
Each of nc_test, nf_test, and nf90_test performs thousands of small writes to test PnetCDF.
On some systems, especially those with storage systems separated from the compute systems, eg. IBM BG machines, these tests will take a long time. Please allocated more time for you job, say 2 hours.
Also, you can compile all test programs before running the tests, by doing the followings.
cd test
make
cd ../examples
make
cd ..
This way your job will run with all test executables already built.
Wei-keng
On May 28, 2015, at 2:00 AM, Carl Ponder wrote:
> On 05/27/2015 06:41 PM, Wei-keng Liao wrote:
>> However, you should see the same error messages when testing C programs, i.e. nc_test. Is it not the case for you?
> Ok -- I did get the same errors in the C part of the testing.
>> As for the issue you encountered when using PGI compilers, can you send me the file config.log and show me the standard output on screen where the program hangs?
>> A successful run of "make check" should look like below. Are you saying it does not show this first line when entering directory nf90_test?
>> *** TESTING F90 ./nf90_test for CDF-1 ------ pass
> Here's the point where it hung
> /shared/apps/centos-6.6_SB/OpenMPI/1.8.5/PGI-15.5_CUDA-7.0_HWLoc-1.10.1_NUMACtl-2.0.9/bin/mpif90 -fPIC -m64 -tp=px -o nf90_test fortlib.o nf90_error.o nf90_test.o test_read.o test_write.o util.o test_get.o test_put.o test_iget.o test_iput.o /shared/apps/centos-6.6_SB/PNetCDF/1.6.0/OpenMPI-1.8.5_PGI-15.5_CUDA-7.0/distro/src/lib/libpnetcdf.a
> rm -f ./scratch.nc ./test.nc
> ./nf90_test -c -d .
> ./nf90_test -d .
> so it finished the F77 tests and had just built the F90 tests.
> This looks like an issue with the PGI 15.5 compiler, I'd like to be able to reproduce the hang if I can.
> The config.log is attached here.
> Thanks,
> Carl
> This email message is for the sole use of the intended recipient(s) and may contain confidential information. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply email and destroy all copies of the original message.
> <config.log>
More information about the parallel-netcdf
