use of MPI derived types in Flexible API
Wei-keng Liao
wkliao at eecs.northwestern.edu
Fri Sep 26 11:06:33 CDT 2014
Hi, Jim
The C documentation is wrong. I will fix that. Thanks for catching the mistake.
Please use it as described in pnetcdf.h
int ncmpi_put_varn_all (int ncid,
int varid,
int num,
const MPI_Offset starts[num][],
const MPI_Offset counts[num][],
const void *bufs,
MPI_Offset bufcounts,
MPI_Datatype buftypes);
FYI. There are a few examples in C and Fortran under examples:
./C/put_varn_float.c
./CXX/put_varn_float.cpp
./F77/put_varn_real.f
./F90/put_varn_real.f90
Wei-keng
On Sep 26, 2014, at 10:52 AM, Jim Edwards wrote:
> Wei-king,
> There is a discrepancy between the documentation and the code with respect to the varn functions. The documentation at http://cucis.ece.northwestern.edu/projects/PNETCDF/doc/pnetcdf-c/ncmpi_005fput_005fvarn_005f_003ctype_003e.html has:
> int varid,
> int num,
> const void *bufs[num],
> MPI_Offset bufcounts[num],
> MPI_Datatype buftypes[num]);
> While the source trunk has:
> int ncmpi_put_varn_all(int ncid, int varid, int num, MPI_Offset* const starts[],
> MPI_Offset* const counts[], const void *buf, MPI_Offset bufcount,
> MPI_Datatype buftype);
> The last three arguments are not arrays.
> - Jim
> On Wed, Sep 24, 2014 at 6:44 PM, Wei-keng Liao <wkliao at eecs.northwestern.edu> wrote:
> If the data is contiguous in memory, then there is no need to use varm or flexible APIs.
> There is a new set of APIs named varn (available in PnetCDF version 1.4.0 and later), eg.
> ncmpi_put_varn_float_all()
> It allows a single API call to write a contiguous buffer to a set of noncontiguous places in file.
> Each noncontiguous place is specified by a (start, count) pair. The start-count pairs can be
> arbitrary in file offsets (i.e. unsorted order in offsets).
> Please note this API family is blocking. There is no nonblocking counterpart.
> In term of performance, this call is equivalent to making multiple iput or bput calls.
> Wei-keng
> On Sep 24, 2014, at 6:58 PM, Jim Edwards wrote:
> > Data is contiguous in memory but data on a given task maps to various non contiguous points in the file. I can guarantee that the data in memory on a given mpi task is in monotonically increasing order with respect to offsets into the file, but not more than that.
> > On Wed, Sep 24, 2014 at 3:43 PM, Wei-keng Liao <wkliao at eecs.northwestern.edu> wrote:
> > Hi, Jim
> > Do you mean the local I/O buffer contains a list of non-contiguous data in memory?
> > Or do you mean "distributed" as data is partitioned across multiple MPI processes?
> > The varm APIs and the "flexible" APIs that take an MPI derived datatype argument
> > are for users to describe non-contiguous data in the local I/O buffer. The imap
> > and MPI datatype argument has no effect to the data access in files. So, I need
> > to know which case you are referring to first.
> > Thanks for pointing out the error in the user guide. It is fixed.
> > Wei-keng
> > On Sep 24, 2014, at 2:30 PM, Jim Edwards wrote:
> > > I want to write a distributed variable to a file and the way the
> > > data is distributed is fairly random with respect to the ordering on the file.
> > > It seems like I can do several things from each task in order to write the data -
> > > • I can specify several blocks of code using start and count and make mulitple calls on each task to ncmpi_bput_vara_all
> > > • I can define an MPI derived type and make a single call to ncmpi_bput_var_all on each task
> > > • I (think I) can use ncmpi_bput_varm_all and specify an imap (btw: the pnetcdf users guide has this interface wrong)
> > > Are any of these better from a performance standpoint?
> > > Thanks,
> > > Jim Edwards
> > > CESM Software Engineer
> > > National Center for Atmospheric Research
> > > Boulder, CO
> > Jim Edwards
> > Boulder, CO
> Jim Edwards
> Boulder, CO
More information about the parallel-netcdf
