use of MPI derived types in Flexible API
Jim Edwards
jedwards at ucar.edu
Fri Sep 26 10:52:58 CDT 2014
Wei-king,
There is a discrepancy between the documentation and the code with respect
to the varn functions. The documentation at
http://cucis.ece.northwestern.edu/projects/PNETCDF/doc/pnetcdf-c/ncmpi_005fput_005fvarn_005f_003ctype_003e.html
has:
int ncmpi_put_varn_all (int ncid,
int varid,
int num,
const MPI_Offset starts[num][],
const MPI_Offset counts[num][],
const void *bufs[num],
MPI_Offset bufcounts[num],
MPI_Datatype buftypes[num]);
While the source trunk has:
int ncmpi_put_varn_all(int ncid, int varid, int num, MPI_Offset* const
starts[],
MPI_Offset* const counts[], const void *buf, MPI_Offset
bufcount,
MPI_Datatype buftype);
The last three arguments are not arrays.
- Jim
On Wed, Sep 24, 2014 at 6:44 PM, Wei-keng Liao <wkliao at eecs.northwestern.edu
> wrote:
> If the data is contiguous in memory, then there is no need to use varm or
> flexible APIs.
> There is a new set of APIs named varn (available in PnetCDF version 1.4.0
> and later), eg.
> ncmpi_put_varn_float_all()
> It allows a single API call to write a contiguous buffer to a set of
> noncontiguous places in file.
> Each noncontiguous place is specified by a (start, count) pair. The
> start-count pairs can be
> arbitrary in file offsets (i.e. unsorted order in offsets).
> Please note this API family is blocking. There is no nonblocking
> counterpart.
> In term of performance, this call is equivalent to making multiple iput or
> bput calls.
> Wei-keng
> On Sep 24, 2014, at 6:58 PM, Jim Edwards wrote:
> > Data is contiguous in memory but data on a given task maps to various
> non contiguous points in the file. I can guarantee that the data in
> memory on a given mpi task is in monotonically increasing order with
> respect to offsets into the file, but not more than that.
> > On Wed, Sep 24, 2014 at 3:43 PM, Wei-keng Liao <
> wkliao at eecs.northwestern.edu> wrote:
> > Hi, Jim
> > Do you mean the local I/O buffer contains a list of non-contiguous data
> in memory?
> > Or do you mean "distributed" as data is partitioned across multiple MPI
> processes?
> > The varm APIs and the "flexible" APIs that take an MPI derived datatype
> argument
> > are for users to describe non-contiguous data in the local I/O buffer.
> The imap
> > and MPI datatype argument has no effect to the data access in files. So,
> I need
> > to know which case you are referring to first.
> > Thanks for pointing out the error in the user guide. It is fixed.
> > Wei-keng
> > On Sep 24, 2014, at 2:30 PM, Jim Edwards wrote:
> > > I want to write a distributed variable to a file and the way the
> > > data is distributed is fairly random with respect to the ordering on
> the file.
> > > It seems like I can do several things from each task in order to write
> the data -
> > > • I can specify several blocks of code using start and count and
> make mulitple calls on each task to ncmpi_bput_vara_all
> > > • I can define an MPI derived type and make a single call to
> ncmpi_bput_var_all on each task
> > > • I (think I) can use ncmpi_bput_varm_all and specify an imap
> (btw: the pnetcdf users guide has this interface wrong)
> > > Are any of these better from a performance standpoint?
> > > Thanks,
> > > Jim Edwards
> > > CESM Software Engineer
> > > National Center for Atmospheric Research
> > > Boulder, CO
> > Jim Edwards
> > Boulder, CO
Jim Edwards
Boulder, CO
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20140926/d7c12681/attachment.html>
More information about the parallel-netcdf
