installation help
Osman Tursun osmanjan.t at gmail.com
Tue Aug 26 09:19:45 CDT 2014
if you need the detailed output result.. you can see the attachment..
On Tue, Aug 26, 2014 at 5:05 PM, Osman Tursun <osmanjan.t at gmail.com> wrote:
> Dear sir, firstly thank you for offering such a great resources.
> Everything is going fine , except some error. I hope you can help me, thank
> you.
> make install
> make  -C src install
> make[1]: Entering directory
> `/home1/e1893122/workspace/parallel-netcdf-1.5.0/src'
> make -w -C lib objs
> make[2]: Entering directory
> `/home1/e1893122/workspace/parallel-netcdf-1.5.0/src/lib'
> make[2]: Nothing to be done for `objs'.
> make[2]: Leaving directory
> make -w -C utils objs
> `/home1/e1893122/workspace/parallel-netcdf-1.5.0/src/utils'
> make -w -C ncmpigen
> make[3]: Entering directory
> `/home1/e1893122/workspace/parallel-netcdf-1.5.0/src/utils/ncmpigen'
> /usr/mpi/gcc/mvapich-1.1.0/bin/mpicc  -c -g -O2   -I. -I../../lib
> -I./../../lib -I. -DHAVE_CONFIG_H  main.c
> -I./../../lib -I. -DHAVE_CONFIG_H  load.c
> -I./../../lib -I. -DHAVE_CONFIG_H  escapes.c
> -I./../../lib -I. -DHAVE_CONFIG_H  getfill.c
> -I./../../lib -I. -DHAVE_CONFIG_H  init.c
> -I./../../lib -I. -DHAVE_CONFIG_H  genlib.c
> -I./../../lib -I. -DHAVE_CONFIG_H  ncmpigentab.c
> /usr/mpi/gcc/mvapich-1.1.0/bin/mpicc  -g -O2   -o ncmpigen main.o load.o
> escapes.o getfill.o init.o genlib.o ncmpigentab.o  -L../../lib -lpnetcdf
> ../../lib/libpnetcdf.a(subfile.o): In function
> `ncmpii_subfile_getput_vars':
> /home1/e1893122/workspace/parallel-netcdf-1.5.0/src/lib/subfile.c:762:
> undefined reference to `MPI_Type_get_extent'
> collect2: ld returned 1 exit status
> make[3]: *** [ncmpigen] Error 1
> make[3]: Leaving directory
> make[2]: *** [ncmpigen] Error 2
> make[1]: *** [utils] Error 2
> make[1]: Leaving directory
> make: *** [install-src] Error 2
> Best wishes
> Osman Tursun
Best wishes
Osman Tursun
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20140826/49fdf8bb/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20140826/49fdf8bb/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/parallel-netcdf/attachments/20140826/49fdf8bb/attachment-0001.obj>
