pnetcdf nfmpi_put_vara_real_all problem
Wong, David
Wong.David-C at epa.gov
Wed Sep 18 12:46:42 CDT 2013
Hi Wei-keng,
start and count have been declared as:
NFMPI_OFFSET :: start(4), count(4)
I have tested in a smaller version of code and it worked. After I put it in our numerical model and it crashed. Any other thought? Please advise.
Cheers,
David
From: Wei-keng Liao <wkliao at ece.northwestern.edu>
Sent: Wednesday, September 18, 2013 1:01 PM
To: Wong, David
Cc: parallel-netcdf at mcs.anl.gov
Subject: Re: pnetcdf nfmpi_put_vara_real_all problem
Hi, David,
Could you send us the code fragment or the program that can reproduce the error?
Just a reminder. The datatype of start and count must be integer*8.
Similarly, use integer*8 to define dimensions.
If you have done that already, there must be something else.
Wei-keng
On Sep 18, 2013, at 11:09 AM, David Wong wrote:
> Hi,
> I am able to create a file:
> netcdf pCTM_CONC_1 {
> dimensions:
> cols = 423 ;
> rows = 594 ;
> lays = 14 ;
> time = UNLIMITED ; // (0 currently)
> vars = 142 ;
> variables:
> float NO2(time, lays, rows, cols) ;
> float NO(time, lays, rows, cols) ;
> float O(time, lays, rows, cols) ;
> The code crashed with a segmentation fault (indicated the following line by traceback option):
> stat = nfmpi_put_vara_real_all (loc_pos%fileid, loc_pos%var_id(v), start, count, loc_data)
> The argument for this call in one of the processor is:
> loc_pos%fileid = 0
> loc_pos%var_id(v) = 1
> start = 1 1 1 1
> count = 423 50 14 1
> loc_data (size) = 423 50 14
> I wonder what is the problem. Please advise.
> Cheers,
> David
More information about the parallel-netcdf
