pnetcdf nfmpi_put_vara_real_all problem
Wei-keng Liao wkliao at ece.northwestern.edu
Wed Sep 18 12:01:13 CDT 2013
Hi, David,
Could you send us the code fragment or the program that can reproduce the error?
Just a reminder. The datatype of start and count must be integer*8.
Similarly, use integer*8 to define dimensions.
If you have done that already, there must be something else.
Wei-keng
On Sep 18, 2013, at 11:09 AM, David Wong wrote:
> Hi,
>    I am able to create a file:
> netcdf pCTM_CONC_1 {
> dimensions:
>         cols = 423 ;
>         rows = 594 ;
>         lays = 14 ;
>         time = UNLIMITED ; // (0 currently)
>         vars = 142 ;
> variables:
>         float NO2(time, lays, rows, cols) ;
>         float NO(time, lays, rows, cols) ;
>         float O(time, lays, rows, cols) ;
> The code crashed with a segmentation fault (indicated the following line by traceback option):
>         stat = nfmpi_put_vara_real_all (loc_pos%fileid, loc_pos%var_id(v), start, count, loc_data)
> The argument for this call in one of the processor is:
> loc_pos%fileid = 0
> loc_pos%var_id(v) = 1
> start =   1    1    1    1
> count = 423   50   14    1
> loc_data (size) = 423     50     14
> I wonder what is the problem. Please advise.
> Cheers,
> David
