bug in pnetcdf.mod
Wei-keng Liao
wkliao at ece.northwestern.edu
Tue Oct 30 17:21:30 CDT 2012
Please try "var2(1)". i.e.
err = nfmpi_put_var_text(ncid, varid(2), var2(1))
Wei-keng
On Oct 30, 2012, at 5:02 PM, Jim Edwards wrote:
> Hi,
> The attached program writes a file of form
> netcdf test {
> // file format: CDF-5 (big variables)
> dimensions:
> Clen1 = 12 ;
> Clen2 = 6 ;
> variables:
> char string1(Clen1) ;
> char string2(Clen2, Clen1) ;
> data:
> string1 = "abcdefghijkl" ;
> string2 =
> "1bcdefghijkl",
> "2bcdefghijkl",
> "3bcdefghijkl",
> "4bcdefghijkl",
> "5bcdefghijkl",
> "6bcdefghijkl" ;
> The program works fine when using #include <pnetcdf.inc> but when trying to use pnetcdf.mod
> it incorrectly gives an error, I believe that the module interface just needs to be expanded to include multi-dimensional character strings. I am using code from the repository svn v1100
> mpxlf95_r pnetcdf-write-bug.F -I/contrib/parallel-netcdf/svn1100/include -L/contrib/parallel-netcdf/svn1100/lib -lpnetcdf -qfixed
> "pnetcdf-write-bug.F", line 79.48: 1513-061 (S) Actual argument attributes do not match those specified by an accessible explicit interface.
> ** main === End of Compilation 1 ===
> 1501-511 Compilation failed for file pnetcdf-write-bug.F.
> Jim Edwards
> CESM Software Engineering Group
> National Center for Atmospheric Research
> Boulder, CO
> 303-497-1842
> <pnetcdf-write-bug.F>
More information about the parallel-netcdf
